Noise at the end of each track befor next track starts
Hi Folks
I am using Studio latest windows version (Audirvana version 2.8.4 and today is 2024-09-10).
Kernel streaming version showed that it has issue with noise (around 1 second) at the end of each track before next track.
After searching , it shows that there is work around if you active volume control and keep it untouched to 0.0 dB , there will be no more noise !
ASIO and WASAPI has not this issue at all.
My question is that this is very old bugs, why they didn’t fix it with all these years?
It seems no body read this forum from Audirvana!
Is there any idea?!
Hi @Paul_65,
If it was easy to fix, we might have fixed it for a long time :stuck_out_tongue:
Unfortunately, it isn’t easy, so we go one step at a time.
Can you send us a copy of the "Debug Infoā€œ when you have this issue? You can get it in Audirvana Settings>My account.
ok, here you are , if that helps !
Audirvana Studio 2.8.4 (20804)
Windows 11 (22631) with 8GB physical RAM
Connected account of : xxxxxxx
Available network interfaces:
Mrgoogle_5G ({fdf59cbf-13ce-4376-86e2-2e736a3cdc89}) is PUBLIC
Mrgoogle_5G ({52ce3ae1-25fa-4c29-8938-07078095014a}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
AUTO: \xxxxxxx\music
Library database path: C:\Users\xxxxx\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
\xxxxxxx\music
Deep Synch: yes
Scanning 390732/2804441: \xxxxxxxx\music\xxxxxxx_1@app@metadata\homes\admin\xxxxxxxx_1@app@metadata\homes\xxxxxxxx\WD_BACKUP_DISK\pc_C_harddisc\library\symbols\passive\swspst2\sym_1_Syno_BkpMetadata.db
Tracks with no MBID: 2287
Listening on 192.168.1.150 on port 53324
Font size: large
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 4096MB
Speakers (Bel Canto uLink Audio)
Model UID:TUSBAUDIO_ENUM\VID_2646&PID_0002&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{8eedeea4-5343-4387-9b0f-74b7581bc8d2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 24bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Selected device:Speakers (Bel Canto uLink Audio)
Manufacturer: Bel Canto
Model name: Bel Canto uLink WDM Audio
Model UID: TUSBAUDIO_ENUM\VID_2646&PID_0002&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{8eedeea4-5343-4387-9b0f-74b7581bc8d2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x2646
USB Product ID: 0x0002
Kernel Streaming capable
Max volume alert: Disabled
DSD via PCM 1.1
Simple stereo device: No
Device #0: Speakers (Bel Canto uLink Audio)
Device #1: TD2230 Series (Intel(R) Display Audio)
Manufacturer: Intel(R) Corporation
Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_280D&SUBSYS_80860101&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{fa6644f2-2f8e-4307-b70a-d0ead304c4c9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Chromecast devices found : 1
Device #0: Chromecast
Model name: Chromecast
Hi @Paul_65,
Suppose you remove this setting in the audio output section of Audirvāna. Do you still get this noise? Other than that, do you get this with specific sample rates?
Hi
I did as you said and let the Audirvana play itself in several hours , then I write down the sample and bit for each song when the noise it comes at next track , results as follow:
there is no correlation , it seems that work around at first place solve the problem, but it is very annoying bug. it is not bit perfect as Audirvana claim in their web site!
1s noise at end 16/44.1khz >>> 24/48khz
no noise 24/48khz >>> 16/44.1khz
1s noise at end 16/44.1khz >>> 16/44.1khz
1s noise at end 16/44.1khz >>> 24/192khz
no noise 24/192khz >>> 24/44.1khz
1s noise at end 24/44.1khz >>> 16/44.1khz
no noise 16/44.1khz >>> 16/44.1khz
no noise 16/44.1khz >>> 24/48khz
Connected account of : xxxxxxxxx
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
AUTO: \KLEYNOD\music
\KLEYNOD\music
Deep Synch: yes
Scanning 417331/2804465: \KLEYNOD\music\KLEYNOD_1@app@metadata\homes\admin\KLEYNOD_1@app@metadata\homes\xxxxxxxxx\WD_BACKUP_DISK\pc_backup\Users\xxxxx\AppData\Roaming\Skype\xxxxx.xxxxxxxx\chatsync\e1_Syno_BkpMetadata.db
Tracks with no MBID: 2361
Listening on 192.168.1.150 on port 49893
Font size: large
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 1
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
DSD via PCM 1.1
Do you have this issue with WASAPI?
We have to work on Kernel Streaming, but such a change requires some time. I can’t tell you when it will be available, but we are aware of this issue and will take care of it.
I too have been dealing with this and tried about everything from removing my fidelizer, changing the buffering, reinstalling program and I can’t remember everything else but to no avail. THEN about a week ago I am not sure what I did but I have not recently gotten that very loud scratch sound when the song auto advances to the next track. If I click on the track change it never made the sound only when I let the album play straight through. I would love to know what causes it. I do have Jplay and do use Kernal streaming Thanks, Jim
Hi,
As I and some others posted (don’t remember what the topic was called) uninstalling ASIO driver worked for me.
Somehow, don’t know how or why, it is related. :slightly_smiling_face:
I use Kernel and since removing the ASIO it never happened again.
I would like to try your fix. How do you remove the ASIO driver but keep the WASAPI? Thanks!
Have the same issue with Kernel streaming. Either a withe noise between tracks or some peeps. Can’t switch to ASIO or WASAPI as running V2.9.4 on a headless PC, causes to stop audio when RDP is closed.
Audirvana Studio 2.9.4 (20904)
Windows 10 (19045) x86_64 with 16GB physical RAM
		Ethernet 2 ({c746f5bf-a2b8-4a35-a74f-9ea6d375f613}) is private
		Private profile:
			Firewall: enabled
			Inbound: allowed
			Outbound: allowed
		Public profile:
			Firewall: enabled
			Inbound: blocked
			Outbound: allowed
		AUTO: \\NAS1\Music_LL\
	Library database path: C:\Users\MultiMedia\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
	Tracks with no MBID: 14489
	Listening on 2001:1c03:3a1d:8800:c5f0:f8a7:187f:a31a on port 56763
	Qobuz:  Connected as Qobuz Studio
	TIDAL:  Connected as PREMIUM
	Font size: regular
		My Music
		Streaming
		Radios
		Podcasts
	Number of paired remotes: 3
	Screen saver disabled: yes
Max. memory for audio buffers: 8192MB
	Speakers (TOPPING USB DAC)
	Model UID:TUSBAUDIO_ENUM\VID_152A&PID_8750&REV_0107&KS
	UID:\\?\SWD#MMDEVAPI#{0.0.0.00000000}.{d883609c-5b98-4109-bcc1-1d3d1b7ae625}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
	Device: 2ch  24bits  Integer, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
	Sample rate switching latency: 1s
Selected device:Speakers (TOPPING USB DAC)
	Manufacturer: Topping
	Model name: E50
	Model UID: TUSBAUDIO_ENUM\VID_152A&PID_8750&REV_0107&KS
	UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{d883609c-5b98-4109-bcc1-1d3d1b7ae625}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
	USB Vendor ID: 0x152a
	USB Product ID: 0x8750
	MQA Decoder device
	DSD via PCM 1.1
	Device #0: Speakers (TOPPING USB DAC)
		Model name: E50
	Device #1: Speakers (2- Realtek High Definition Audio)
		Manufacturer: Realtek
		Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0221&SUBSYS_103C1825&REV_1000
		UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{c7adda46-22d0-411a-8135-8b0feb20c764}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
