I’m enjoying Audirvana on Arch Linux, but I’m having some trouble. When I play songs in the order of the playlist, there is noise at the transitions between songs. Is there anything I can do about this? I’m connecting it to a DAC using diretta, could that be one of the causes?
Hi @Oioikk99 ,
Hi,@Antoine!
Thank you for the advice. I will paste it as specified.
Audirvana Studio 2.11.5
Running on Micro-Star International Co., Ltd. MS-7D13
Linux 6.16.6-1-cachyos-rt-bore-lto x86_64 x86_64 with 11.5GB physical RAM
Connected account of :
LOADING/DECODING:
Max audio buffer size: 1212MB
Internal EQ: OFF
AUTO: /var/share/music/
Sync folders at startup: YES
Sort and display order: en
Library database path: /home/hqpe/.local/share/audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 1549
Listening on on port 35047
Font size: regular
Language: 日本語
マイミュージック
ストリーミング
ローカル
ラジオ
ポッドキャスト
Startup view: マイ ミュージック: アルバム
Number of paired remotes: 2
Max. memory for audio buffers: 1212MB
Local Audio Engine: Linux ALSA library 1.2.14
Advanced Linux Sound Architecture Driver Version k6.16.6-1-cachyos-rt-bore-lto.
OLIO.SPEC_Bridge_72E6
Model UID:OLIO.SPEC_Bridge_72E6
UID:OLIO.SPEC_Bridge_72E6:MolaMola USB Audio 2.0
Device: 2ch 24bits Integer, 6 bytes per frame 48kHz
Active Sample Rate: 48kHz
Sample rate switching latency: 1s
Selected device:OLIO.SPEC_Bridge_72E6
Manufacturer:
Model name: OLIO.SPEC_Bridge_72E6
Model UID: OLIO.SPEC_Bridge_72E6
UID: OLIO.SPEC_Bridge_72E6:MolaMola USB Audio 2.0
2822400
5644800
11289600
22579200
Raw DSD (32bit MSB)
Simple stereo device: No
1 ch Integer PCM 16bit little endian 44.1kHz
1 ch Integer PCM 24bit little endian 44.1kHz
1 ch Integer PCM 32bit little endian 44.1kHz
1 ch Integer PCM 16bit little endian 48kHz
1 ch Integer PCM 24bit little endian 48kHz
1 ch Integer PCM 32bit little endian 48kHz
1 ch Integer PCM 16bit little endian 88.2kHz
1 ch Integer PCM 24bit little endian 88.2kHz
1 ch Integer PCM 32bit little endian 88.2kHz
1 ch Integer PCM 16bit little endian 96kHz
1 ch Integer PCM 24bit little endian 96kHz
1 ch Integer PCM 32bit little endian 96kHz
1 ch Integer PCM 16bit little endian 176.4kHz
1 ch Integer PCM 24bit little endian 176.4kHz
1 ch Integer PCM 32bit little endian 176.4kHz
1 ch Integer PCM 16bit little endian 192kHz
1 ch Integer PCM 24bit little endian 192kHz
1 ch Integer PCM 32bit little endian 192kHz
1 ch Integer PCM 16bit little endian 352.8kHz
1 ch Integer PCM 24bit little endian 352.8kHz
1 ch Integer PCM 32bit little endian 352.8kHz
1 ch Integer PCM 16bit little endian 384kHz
1 ch Integer PCM 24bit little endian 384kHz
1 ch Integer PCM 32bit little endian 384kHz
1 ch Integer PCM 16bit little endian 705.6kHz
1 ch Integer PCM 24bit little endian 705.6kHz
1 ch Integer PCM 32bit little endian 705.6kHz
1 ch Integer PCM 16bit little endian 768kHz
1 ch Integer PCM 24bit little endian 768kHz
1 ch Integer PCM 32bit little endian 768kHz
1 ch DSD 32bit big endian in 32bit chunk 2822.4kHz
1 ch DSD 32bit big endian in 32bit chunk 5644.8kHz
1 ch DSD 32bit big endian in 32bit chunk 11289.6kHz
1 ch DSD 32bit big endian in 32bit chunk 22579.2kHz
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
2 ch DSD 32bit big endian in 32bit chunk 2822.4kHz
2 ch DSD 32bit big endian in 32bit chunk 5644.8kHz
2 ch DSD 32bit big endian in 32bit chunk 11289.6kHz
2 ch DSD 32bit big endian in 32bit chunk 22579.2kHz
Device #0: HD-Audio Generic
Manufacturer:
Model UID: HD-Audio Generic
UID: HD-Audio Generic at 0xfcc80000 irq 77
Model name: HD-Audio Generic
Device #1: OLIO.SPEC_Bridge_72E6
Manufacturer:
eth0
Can you please remove this settings in the DAC in Audirvāna audio? Once you have done this, please try again to reproduce your issue.
