my setting
Audirvana 3.5.43
Sync list: 13 folders
AUTO: E:\01 - Art Ensemble of Chicago - Nice Guys (1979)
AUTO: E:\02 - Art Ensemble of Chicago - Full Force (1980)
AUTO: E:\12 - Roscoe Mitchell - Composition-Improvisation Nos.1, 2 & 3 (2007)
AUTO: E:\15 - Roscoe Mitchell - Bells for the South Side_cd1
AUTO: E:\15 - Roscoe Mitchell - Bells for the South Side_cd2
AUTO: E:\16 - Jack DeJohnette - New Directions (1978)
AUTO: E:\1965__Thelonious_Monk_-Misterioso__Recorded_On_Tour___2017___24-192
AUTO: E:\Kronos Quartet & Ron Carter - Monk Suite- Kronos Quartet Plays Music of Thelonious Monk with Special Guest Artist Ron Carter [1985]
AUTO: E:\Larry_Young_-In_Paris-The_ORTF_Recordings__2016_5_6_MHz1_Bit
AUTO: E:\M_Ravel-Daphnis_et_Chloe__SHM-SACD__BSO___Ozawa_iso
AUTO: E:\Prokofiev___Shostakovich-2011-Cantata_for_the_20th_Anniversary_of_the_October_Revolution___The_Sun_Shines_over_our_Motherland__Kirill_Kondrashin__Moscow_Philharmonic_Orchestra_-FLAC-24
AUTO: E:\Thelonious Monk - Les Liaisons Dangereuses 1960 (2017) [Hi-Res stereo]
AUTO: E:\hiresflac\Kronos_Quartet___Ron_Carter-_Monk_Suite-Kronos_Quartet_Plays_Music_of_Thelonious_Monk_with_Special_Guest_Artist_Ron_Carter__1985
Library database path: C:\Users\dthbo\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 12380MB
Local Audio Engine:ASIO 2 driver version 2
Digital Output (Chord Async USB 44.1kHz-384kHz)
Model UID:Digital Output (Chord Async USB 44.1kHz-384kHz)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{2354583f-9c92-42ec-ba03-8d3a206527d8}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 2822.4kHz
ASIO Chord 1.04 Manufacturer:
Model UID:ASIO Chord 1.04 UID:ASIO Chord 1.04
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: ASIO Chord 1.04 Manufacturer: Model UID: ASIO Chord 1.04 UID: ASIO Chord 1.04
