Noise
Hello everyone
Sometimes when I play a song, I get noise instead of music.
Is there an explanation for this? Do I need to adjust a setting?
“Noise” is an ambiguous term that is associated to many potential aspects of any given playback system scenario.
More information is needed… please describe your playback scenario and include your platform configuration and please provide your debug information report so folks can view the synergy of your OS platform and DAC hardware attributes with the configuration of Audirvāna so to provide insightful help… Follow these guidelines:
And review the trouble-shooting information found in the Knowledge base:
I guess white noise?? Ssssssssssshhhhhhhhhhhhhh noise that never end, until you go fast to your remote and or system to shut down volume fast…
I know guessing is not allowed here
More context is needed in order to attempt making an educated guess… :wink:
Go to settings, the DAC input item, toggle ‘Fix for devices with unwanted playback stop’. See if that cures the problem.
your advice worked
I had the desynchronization issue again; here is the Debug info log.
Audirvana Studio 2.11.6
Running on ASUSTeK COMPUTER INC. NUC13ANK
Linux 6.14.5-x86_64-GentooPlayer-ST-RT x86_64 x86_64 with 15.2GB physical RAM
Connected account of : LOIC GISQUET
LOADING/DECODING:
Max audio buffer size: 7774MB
Internal EQ: OFF
r8brain to DSD256 with filter type B 7th order
Bandwidth = 97.702%
Stop band attenuation 180.103dB
Max allowed volume: 0
AUTO: /media/ssd/Music
Sync folders at startup: YES
Sort and display order: en
Library database path: /root/.local/share/audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 1089
Listening on on port 44899
TIDAL: Connected as PREMIUM
Font size: regular
Language: Français
Ma Musique
Radios
Podcasts
Streaming
Startup view: Ma Musique : Albums
Number of paired remotes: 2
Active method: UPnP
eth0
Preferred device: [UPnP] DMP-A6 Model UID:EVERSOLO AV Renderer Device UID:uuid:18ABEECA-DB2E-11F0-A7C6-800A805C24B1
Currently playing to UPnP device at 32 bits 705.6kHz
Selected device:DMP-A6
Manufacturer: EVERSOLO
Model name: AV Renderer Device
Model UID: EVERSOLO AV Renderer Device
UID: uuid:18ABEECA-DB2E-11F0-A7C6-800A805C24B1
UPnP device at http://192.168.1.210:1422/description.xml
Volume control: Yes
Max volume alert: Disabled
DSD via PCM 1.0
UPnP set capabilities
Maximum PCM bitdepth set: 32
Not native DSD capable
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get::image/x-ycbcr-yuv420:
http-get::image/x-xpixmap:
http-get::image/x-xfig:
http-get::image/x-xbm:
http-get::image/x-xbitmap:
http-get::image/x-wmf:
http-get::image/x-windows-bmp:
http-get::image/x-rgb:
http-get::image/x-quicktime:
http-get::image/x-psd:
http-get::image/x-portable-pixmap:
http-get::image/x-portable-graymap:
http-get::image/x-portable-bitmap:
http-get::image/x-portable-anymap:
http-get::image/x-png:
http-get::image/x-pict:
http-get::image/x-photoshop:
http-get::image/x-pcx:
http-get::image/x-ms-bmp:
http-get::image/x-jg:
http-get::image/x-icon:
http-get::image/xicon:
http-get::image/x-ico:
http-get::image/x-guffaw:
http-get::image/x-eps:
http-get::image/x-emf:
http-get::image/x.djvu:
http-get::image/x-djvu:
http-get::image/x-dcraw:
http-get::image/x-citrix-pjpeg:
http-get::image/x-bmp:
http-get::image/x-bitmap:
http-get::image/vnd.wap.wbmp:
http-get::image/vnd.ms-photo:
http-get::image/vnd.ms-modi:
http-get::image/vnd.microsoft.icon:
http-get::image/vnd.dxf:
http-get::image/vnd.dwg:
http-get::image/vnd.djvu:
http-get::image/vnd.adobe.photoshop:
http-get::image/tiff:
http-get::image/svg+xml:
http-get::image/png:
http-get::image/pjpeg:
http-get::image/pict:
http-get::image/pdf:
http-get::image/jpg:
http-get::image/jpeg-cmyk:
http-get::image/jpeg:
http-get::image/jp2:
http-get::image/icon:
http-get::image/ico:
http-get::image/GIF:
http-get::image/gif:
http-get::image/fits:
http-get::image/cur:
http-get::image/bmp:
http-get::image/bitmap:
http-get::application/x-shockwave-flash:
http-get::video/m3u8:
http-get::video/ogm:
http-get::video/hlv:
http-get::video/wtv:
http-get::video/x-rmvb:
http-get::video/rmvb:
http-get::video/x-rm:
http-get::video/rm:
http-get::video/x-nerodigital-ps:
http-get::video/wt:
http-get::video/x-matroska:
http-get::video/mkv:
http-get::video/x-mkv:
http-get::video/x-ms-avi:
http-get::video/x-xvid:
http-get::video/xvid:
http-get::video/x-divx:
http-get::video/divx:
http-get::video/x-motion-jpeg:
http-get::video/vnd.dlna.mpeg-tts:
http-get::video/x-swf:
http-get::video/x-sgi-movie:
http-get::video/x-ms-video:
http-get::video/x-pn-realvideo:
http-get::video/x-pn-realaudio:
http-get::video/x-ms-wvx:
http-get::video/x-ms-wmx:
http-get::video/x-ms-wmv:
http-get::video/x-ms-wma:
http-get::video/x-ms-wm:
http-get::video/x-msvideo:
http-get::video/x-ms-asx:
http-get::video/x-ms-asf:
http-get::video/mp2p:
http-get::video/MP2T:
http-get::video/mpeg2:
http-get::video/x-mpeg:
http-get::video/x-mp4:
http-get::video/x-m4v:
http-get::video/x-flv:
http-get::video/x-dv:
http-get::video/wmv:
http-get::video/webm:
http-get::video/vnd.objectvideo:
http-get::video/unknown:
http-get::video/swf:
http-get::video/quicktime:
http-get::video/msvideo:
http-get::video/mpg4:
http-get::video/mpeg4:
http-get::video/mpeg3:
http-get::video/mpeg:
http-get::video/mp4v-es:
http-get::video/mp4:
http-get::video/m4v:
http-get::video/flv:
http-get::video/f4v:
http-get::video/avi:
http-get::video/asx:
http-get::video/3gpp2:
http-get::video/3gpp:
http-get::video/ape:
http-get::video/aiff:
http-get::video/ra:
http-get::video/flac:
http-get::video/ac3:
http-get::video/aac:
http-get::video/ogg:
http-get::video/m4a:
http-get::video/wav:
http-get::video/asf:
http-get::video/wma:
http-get::video/mp3:
http-get::audio/ape:
http-get::audio/x-asf-pf:
http-get::audio/wma:
http-get::audio/x-wav:
http-get::audio/vorbis:
http-get::audio/x-scpls:
http-get::audio/x-ra:
http-get::audio/ra:
http-get::audio/x-realaudio:
http-get::audio/x-pn-realaudio-plugin:
http-get::audio/x-pn-realaudio:
http-get::audio/x-ms-wmv:
http-get::audio/x-ms-wma:
http-get::audio/x-ms-wax:
http-get::audio/x-mpeg-url:
http-get::audio/x-mpeg3:
http-get::audio/x-mp3:
http-get::audio/x-midi:
http-get::audio/x-m4a:
http-get::audio/x-flac:
http-get::audio/flac:
http-get::audio/x-ac3:
http-get::audio/ac3:
http-get::audio/x-aac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/vnd.rn-realaudio:
http-get::audio/vnd.qcelp:
http-get::audio/unknown:
http-get::audio/playlist:
http-get::audio/x-ogg:
http-get::audio/ogg:
http-get::audio/mpg:
http-get::audio/mpeg-url:
http-get::audio/mpeg3:
http-get::audio/mpeg2:
http-get::audio/x-mpeg:
http-get::audio/mpeg:
http-get::audio/mp4a-latm:
http-get::audio/mp4:
http-get::audio/mp3:
http-get::audio/mp2:
http-get::audio/mp1:
http-get::audio/x-dts:
http-get::audio/midi:
http-get::audio/mid:
http-get::audio/m4a:
http-get::audio/x-atrac3:
http-get::audio/basic:
http-get::audio/asf:
http-get::audio/aiff:
http-get::audio/L16:
http-get::audio/L8:
http-get:
:audio/L16:DLNA.ORG_PN=LPCM_low
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/mpeg:DLNA.ORG_PN=MP3
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get::audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_192
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_MULT5_ADTS
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO_192
http-get::audio/3gpp:DLNA.ORG_PN=AAC_ISO_192
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_MULT5_ISO
http-get::audio/3gpp:DLNA.ORG_PN=AAC_MULT5_ISO
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L2
http-get::audio/3gpp:DLNA.ORG_PN=HEAACv2_L2
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_128
http-get::audio/3gpp:DLNA.ORG_PN=HEAACv2_L2_128
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L3
http-get::audio/3gpp:DLNA.ORG_PN=HEAACv2_L3
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L4
http-get::audio/3gpp:DLNA.ORG_PN=HEAACv2_L4
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_MULT5
http-get::audio/3gpp:DLNA.ORG_PN=HEAACv2_MULT5
http-get:
:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO
http-get::audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO
http-get:
:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_128
http-get::audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO_128
http-get:
:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_320
http-get::audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO_320
http-get:
:audio/mp4:DLNA.ORG_PN=HEAAC_L3_ISO
http-get::audio/3gpp:DLNA.ORG_PN=HEAAC_L3_ISO
http-get:
:audio/mp4:DLNA.ORG_PN=HEAAC_MULT5_ISO
http-get::audio/3gpp:DLNA.ORG_PN=HEAAC_MULT5_ISO
http-get:
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMALSL_MULT5
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMABASE
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMAFULL
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMALSL
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMALSL_MULT5
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMAPRO
http-get:
:image/jpeg:DLNA.ORG_PN=JPEG_TN
http-get::image/jpeg:DLNA.ORG_PN=JPEG_SM
http-get:
:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO
http-get::image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get:
:image/jpeg:DLNA.ORG_PN=JPEG_LRG
http-get::image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO
http-get:
:image/png:DLNA.ORG_PN=PNG_LRG
http-get::image/png:DLNA.ORG_PN=PNG_LRG_ICO
http-get:
:image/png:DLNA.ORG_PN=PNG_TN
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVSPML_BASE
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVSPLL_BASE
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVMED_PRO
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVHIGH_FULL
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVMED_FULL
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVHIGH_PRO
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVHM_BASE
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVMED_BASE
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVSPML_MP3
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE
http-get:
:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE
http-get::video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L2_WMA
http-get:
:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA
http-get::video/x-ms-asf:DLNA.ORG_PN=WMDRM_VC1_ASF_AP_L1_WMA
http-get:
:video/x-ms-asf:DLNA.ORG_PN=WMDRM_VC1_ASF_AP_L2_WMA
http-get::video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L4_SO_G726
http-get:
:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_SP_G726
http-get::video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L5_SO_G726
http-get:
:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_ISO
http-get::video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_ISO
http-get::video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_ISO
http-get::video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO
http-get::video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_ISO
http-get::video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO
http-get::video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG1
http-get::video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_ISO
http-get:
:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_ISO
http-get:
:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC
http-get::video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_HEAAC
http-get:
:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC
http-get::video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AMR
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_350
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_HEAAC
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_HEAAC_350
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_940
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_MULT5
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_HEAAC_L2
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_MPEG1_L3
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L12_CIF15_HEAAC
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L12_CIF15_HEAACv2
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L12_CIF15_HEAACv2_350
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L1B_QCIF15_HEAAC
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L1B_QCIF15_HEAACv2
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L2_CIF30_AAC
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L31_HD_AAC
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L32_HD_AAC
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_HEAAC
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3_SD_AAC
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LC
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_HEAAC_L2
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_HEAAC_L4
http-get:
:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_MPEG1_L3
http-get::video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC
http-get:
:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_HEAAC
http-get::video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_HEAAC_MULT5
http-get:
:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC
http-get::video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_HEAAC
http-get:
:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AAC
http-get::video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_AAC
http-get:
:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_HEAAC
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_T
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3
http-get:
:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_T
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
2 ch Integer PCM 16bit little endian 705.6kHz finite length
2 ch Integer PCM 24bit little endian 705.6kHz finite length
2 ch Integer PCM 32bit little endian 705.6kHz finite length
2 ch Integer PCM 16bit little endian 768kHz finite length
2 ch Integer PCM 24bit little endian 768kHz finite length
2 ch Integer PCM 32bit little endian 768kHz finite length
NrTracks: 1
MediaDuration: 0:03:58
CurrentURI: http://192.168.1.49:49152/audirvana/audio_f_15.wav
CurrentURIMetadata:
dc:titleSalsa Movar</dc:title>
dc:creatorHadouk Trio</dc:creator>
upnp:artistHadouk Trio</upnp:artist>
<upnp:author role=“Composer”>Didier Malherbe/Loy Ehrlich</upnp:author>
upnp:genreJazz</upnp:genre>
upnp:albumArtURIhttp://192.168.1.49:49152/audirvana/artwork_1_15.jpg</upnp:albumArtURI>
upnp:albumShamanimal</upnp:album>
upnp:originalTrackNumber6</upnp:originalTrackNumber>
nextURI: http://192.168.1.49:49152/audirvana/audio_f_17.wav
Moussa Hadouk Trio Hadouk Trio Didier Malherbe Jazz http://192.168.1.49:49152/audirvana/artwork_0_17.jpg Shamanimal 7 object.item.audioItem.musicTrack http://192.168.1.49:49152/audirvana/audio_f_17.wav
PlayMedium: NONE
Current transport actions:
Play,Pause,Stop,Seek,Next,Previous
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 / DMP-A6 EVERSOLO http://www.eversolo.com Plutinosoft AV Media Renderer Device AV Renderer Device http://www.plutinosoft.com/platinum uuid:18ABEECA-DB2E-11F0-A7C6-800A805C24B1 DMR-1.50 image/png 64 64 16 /images/icon-64x64.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/scpd.xml /AVTransport/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/control.xml /AVTransport/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/event.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/scpd.xml /ConnectionManager/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/control.xml /ConnectionManager/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/event.xml urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/scpd.xml /RenderingControl/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/control.xml /RenderingControl/18ABEECA-DB2E-11F0-A7C6-800A805C24B1/event.xml
UPnP devices found : 3
Device #0: Marantz CINEMA 70s
UID: uuid:9c304e0e-0f7b-1fb1-0080-000678ceab4f
Location: http://192.168.1.35:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz CINEMA 70s
Device #1: DMP-A6
Device #2: HQPlayerEmbedded:SignalystHQPlayer5
UID: uuid:b48cbc10-b424-4401-930f-b441698ba602
Location: http://192.168.1.49:33806/b48cbc10-b424-4401-930f-b441698ba602.xml
Manufacturer: Rygel Developers
Model name: Rygel
Max. memory for audio buffers: 7774MB
Local Audio Engine: Linux ALSA library 1.2.14
Advanced Linux Sound Architecture Driver Version k6.14.5-x86_64-GentooPlayer-ST-RT.
Local devices found : 3
Device #0: Loopback - Loopback PCM
Manufacturer:
Model UID: Loopback - Loopback PCM
UID: Loopback 1 - Loopback PCM
Model name: Loopback
Device #1: Loopback - Loopback PCM
Manufacturer:
Device #2: HDA Intel PCH
Manufacturer:
Model UID: HDA Intel PCH
UID: HDA Intel PCH at 0x61241b0000 irq 178
Model name: HDA Intel PCH
Try lowering your playback pre-load memory allocation to 2GB… You are allocating 50% of your System RAM for playback pre-load buffering…
Also… The DMP-A6 does not support .dFF files (DSD) via UPnP… If you want to up-sample your PCM files, use ‘Power of Two’ strategy and this will produce a logical up-sampling target of 705.6kHz or 768kHz depending on the source sample-rate… Modulating to DSD256 will not work, as the 1-bit files are transmitted as .dff via UPnP on the Ethernet bus.
Also, you are using Loopback which may be causing problems… Try disabling this to get a working operational baseline reference… Loopback can also be creating latencies due to the nature of the routing function and Audirvāna wants complete control of the output bus(s).
From the Knowledge base article linked below…
DSD playback doesn’t work
When playing to a UPNP device capable of supporting DSD with Audirvāna, the device must state it supports DFF. This information is available once your device is selected as an audio output in Audirvāna and going on the debug info.
Hello
Where do I go to disable Loopback ?
I don’t experience this every time, but it happens occasionally.
Thanks for your help.
