Nordvpn audiravana
I have the following problem, I play music withaudirvana through WiFi to my CA evo150. If I enable nord vpn audirvana is not seeing my evo150 and when I choose from audirvana output nordvpn the audirvana hangs up. Any idea how to create an exception for audirvana to access network when nordvpn is active?
Managed to solve it. It can close
How did you solve this?
Settings-Split Tunneling:
  • Split Tunneling-on,
  • Type-Disable VPN for selected apps,
  • Add Apps: check Audirvana Origin/Studio’s box from the list while Audirvana is running.’
