Not able to play qobuz files ,it seems to load the file but do not start to play.
If I try to play from library it works…some time D:
Tks Giovanni.
Audirvana 3.5.12
AUTO: D:\gio_b_music
Library database path: C:\Users\giovanni\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: JPLAY FEMTO Model UID:jplay.eu JPLAY FEMTO UID:uuid:JPLAY192.168.1.43-MediaRenderer
UPnP device at http://192.168.1.43:48167/JPLAY192.168.1.43-MediaRenderer/Upnp/device.xml
JPLAY FEMTO Manufacturer:jplay.eu
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/flac:*
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-alac:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/x-aiff:
http-get::audio/aiff:
http-get::audio/mp4:
http-get::audio/x-ms-wma:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 1
MediaDuration: 0:09:35
CurrentURI: http://192.168.1.43:49152/audirvana/audio_1_19.wav
CurrentURIMetadata: <DIDL-Lite xmlns:dc="DCMI: DCMI Metadata Terms" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">
<item id="1" parentID="0" restricted="1">
<dc:title>Brazil</dc:title>
<dc:creator>Antonio Carlos Jobim</dc:creator>
<upnp:artist>Antonio Carlos Jobim</upnp:artist>
<upnp:genre>Lo-Fi</upnp:genre>
<upnp:albumArtURI>http://192.168.1.43:49152/audirvana/artwork_1_20.jpg</upnp:albumArtURI>
<upnp:album>Private Collection - Richard Dorfmeister</upnp:album>
<upnp:originalTrackNumber>4</upnp:originalTrackNumber>
<upnp:class>object.item.audioItem.musicTrack</upnp:class>
<res duration="0:09:35.000" size="101552348" protocolInfo="http-get::audio/wav:" sampleFrequency="44100" bitsPerSample="16" nrAudioChannels="2">http://192.168.1.43:49152/audirvana/audio_1_19.wav</res>
</item>
</DIDL-Lite>
nextURI: http://192.168.1.43:49152/audirvana/audio_0_20.wav
<item id="0" parentID="0" restricted="1">
<dc:title>Slabo Day</dc:title>
<dc:creator>Peter Green</dc:creator>
<upnp:artist>Peter Green</upnp:artist>
<upnp:albumArtURI>http://192.168.1.43:49152/audirvana/artwork_0_21.jpg</upnp:albumArtURI>
<upnp:originalTrackNumber>5</upnp:originalTrackNumber>
<res duration="0:04:59.000" size="52795388" protocolInfo="http-get::audio/wav:" sampleFrequency="44100" bitsPerSample="16" nrAudioChannels="2">http://192.168.1.43:49152/audirvana/audio_0_20.wav</res>
</item>
</DIDL-Lite>
PlayMedium: NETWORK
<?xml version="1.0"?> 1 1 SetAVTransportURI InstanceID in A_ARG_TYPE_SetAVTransportURI_InstanceID CurrentURI in A_ARG_TYPE_SetAVTransportURI_CurrentURI CurrentURIMetaData in A_ARG_TYPE_SetAVTransportURI_CurrentURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_SetNextAVTransportURI_InstanceID NextURI in A_ARG_TYPE_SetNextAVTransportURI_NextURI NextURIMetaData in A_ARG_TYPE_SetNextAVTransportURI_NextURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_GetMediaInfo_InstanceID NrTracks out A_ARG_TYPE_GetMediaInfo_NrTracks MediaDuration out A_ARG_TYPE_GetMediaInfo_MediaDuration CurrentURI out A_ARG_TYPE_GetMediaInfo_CurrentURI CurrentURIMetaData out A_ARG_TYPE_GetMediaInfo_CurrentURIMetaData NextURI out A_ARG_TYPE_GetMediaInfo_NextURI NextURIMetaData out A_ARG_TYPE_GetMediaInfo_NextURIMetaData PlayMedium out A_ARG_TYPE_GetMediaInfo_PlayMedium RecordMedium out A_ARG_TYPE_GetMediaInfo_RecordMedium WriteStatus out A_ARG_TYPE_GetMediaInfo_WriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_GetTransportInfo_InstanceID CurrentTransportState out A_ARG_TYPE_GetTransportInfo_CurrentTransportState CurrentTransportStatus out A_ARG_TYPE_GetTransportInfo_CurrentTransportStatus CurrentSpeed out A_ARG_TYPE_GetTransportInfo_CurrentSpeed GetPositionInfo InstanceID in A_ARG_TYPE_GetPositionInfo_InstanceID Track out A_ARG_TYPE_GetPositionInfo_Track TrackDuration out A_ARG_TYPE_GetPositionInfo_TrackDuration TrackMetaData out A_ARG_TYPE_GetPositionInfo_TrackMetaData TrackURI out A_ARG_TYPE_GetPositionInfo_TrackURI RelTime out A_ARG_TYPE_GetPositionInfo_RelTime AbsTime out A_ARG_TYPE_GetPositionInfo_AbsTime RelCount out A_ARG_TYPE_GetPositionInfo_RelCount AbsCount out A_ARG_TYPE_GetPositionInfo_AbsCount GetDeviceCapabilities InstanceID in A_ARG_TYPE_GetDeviceCapabilities_InstanceID PlayMedia out A_ARG_TYPE_GetDeviceCapabilities_PlayMedia RecMedia out A_ARG_TYPE_GetDeviceCapabilities_RecMedia RecQualityModes out A_ARG_TYPE_GetDeviceCapabilities_RecQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_GetTransportSettings_InstanceID PlayMode out A_ARG_TYPE_GetTransportSettings_PlayMode RecQualityMode out A_ARG_TYPE_GetTransportSettings_RecQualityMode Stop InstanceID in A_ARG_TYPE_Stop_InstanceID Play InstanceID in A_ARG_TYPE_Play_InstanceID Speed in A_ARG_TYPE_Play_Speed Pause InstanceID in A_ARG_TYPE_Pause_InstanceID Seek InstanceID in A_ARG_TYPE_Seek_InstanceID Unit in A_ARG_TYPE_Seek_Unit Target in A_ARG_TYPE_Seek_Target Next InstanceID in A_ARG_TYPE_Next_InstanceID Previous InstanceID in A_ARG_TYPE_Previous_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_GetCurrentTransportActions_InstanceID Actions out A_ARG_TYPE_GetCurrentTransportActions_Actions LastChange string A_ARG_TYPE_SetAVTransportURI_InstanceID ui4 A_ARG_TYPE_SetAVTransportURI_CurrentURI string A_ARG_TYPE_SetAVTransportURI_CurrentURIMetaData string A_ARG_TYPE_SetNextAVTransportURI_InstanceID ui4 A_ARG_TYPE_SetNextAVTransportURI_NextURI string A_ARG_TYPE_SetNextAVTransportURI_NextURIMetaData string A_ARG_TYPE_GetMediaInfo_InstanceID ui4 A_ARG_TYPE_GetMediaInfo_NrTracks ui4 A_ARG_TYPE_GetMediaInfo_MediaDuration string A_ARG_TYPE_GetMediaInfo_CurrentURI string A_ARG_TYPE_GetMediaInfo_CurrentURIMetaData string A_ARG_TYPE_GetMediaInfo_NextURI string A_ARG_TYPE_GetMediaInfo_NextURIMetaData string A_ARG_TYPE_GetMediaInfo_PlayMedium string A_ARG_TYPE_GetMediaInfo_RecordMedium string A_ARG_TYPE_GetMediaInfo_WriteStatus string NOT_IMPLEMENTED NOT_WRITABLE PROTECTED UNKNOWN WRITABLE A_ARG_TYPE_GetTransportInfo_InstanceID ui4 A_ARG_TYPE_GetTransportInfo_CurrentTransportState string NO_MEDIA_PRESENT PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING STOPPED TRANSITIONING A_ARG_TYPE_GetTransportInfo_CurrentTransportStatus string ERROR_OCCURRED OK A_ARG_TYPE_GetTransportInfo_CurrentSpeed string A_ARG_TYPE_GetPositionInfo_InstanceID ui4 A_ARG_TYPE_GetPositionInfo_Track ui4 0 2147483647 1 A_ARG_TYPE_GetPositionInfo_TrackDuration string A_ARG_TYPE_GetPositionInfo_TrackMetaData string A_ARG_TYPE_GetPositionInfo_TrackURI string A_ARG_TYPE_GetPositionInfo_RelTime string A_ARG_TYPE_GetPositionInfo_AbsTime string A_ARG_TYPE_GetPositionInfo_RelCount i4 A_ARG_TYPE_GetPositionInfo_AbsCount i4 A_ARG_TYPE_GetDeviceCapabilities_InstanceID ui4 A_ARG_TYPE_GetDeviceCapabilities_PlayMedia string A_ARG_TYPE_GetDeviceCapabilities_RecMedia string A_ARG_TYPE_GetDeviceCapabilities_RecQualityModes string A_ARG_TYPE_GetTransportSettings_InstanceID ui4 A_ARG_TYPE_GetTransportSettings_PlayMode string NORMAL A_ARG_TYPE_GetTransportSettings_RecQualityMode string A_ARG_TYPE_Stop_InstanceID ui4 A_ARG_TYPE_Play_InstanceID ui4 A_ARG_TYPE_Play_Speed string A_ARG_TYPE_Pause_InstanceID ui4 A_ARG_TYPE_Seek_InstanceID ui4 A_ARG_TYPE_Seek_Unit string ABS_COUNT ABS_TIME CHANNEL_FREQ FRAME REL_COUNT REL_TIME TAPE-INDEX TRACK_NR A_ARG_TYPE_Seek_Target string A_ARG_TYPE_Next_InstanceID ui4 A_ARG_TYPE_Previous_InstanceID ui4 A_ARG_TYPE_GetCurrentTransportActions_InstanceID ui4 A_ARG_TYPE_GetCurrentTransportActions_Actions stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 image/png> http://192.168.1.43:48167/JPLAY192.168.1.43femtoServer/Upnp/resource/2 JPLAY FEMTO [jplay.eu](http://jplay.eu/) JPLAY uuid:JPLAY192.168.1.43-MediaRenderer urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /JPLAY192.168.1.43-MediaRenderer/Upnp/upnp.org-ConnectionManager-1/service.xml /JPLAY192.168.1.43-MediaRenderer/upnp.org-ConnectionManager-1/control /JPLAY192.168.1.43-MediaRenderer/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /JPLAY192.168.1.43-MediaRenderer/Upnp/upnp.org-RenderingControl-1/service.xml /JPLAY192.168.1.43-MediaRenderer/upnp.org-RenderingControl-1/control /JPLAY192.168.1.43-MediaRenderer/upnp.org-RenderingControl-1/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /JPLAY192.168.1.43-MediaRenderer/Upnp/upnp.org-AVTransport-1/service.xml /JPLAY192.168.1.43-MediaRenderer/upnp.org-AVTransport-1/control /JPLAY192.168.1.43-MediaRenderer/upnp.org-AVTransport-1/eventUPnP devices found : 2
Device #0BubbleUPnP (SM-G965F) UID: uuid:c3f4fef7-58b9-4946-825b-c788e14d9307 Location: http://192.168.1.244:58645/dev/c3f4fef7-58b9-4946-825b-c788e14d9307/desc.xml
Device #1JPLAY FEMTO UID: uuid:JPLAY192.168.1.43-MediaRenderer Location: http://192.168.1.43:48167/JPLAY192.168.1.43-MediaRenderer/Upnp/device.xml
Max. memory for audio buffers: 2698MB
Local Audio Engine:WASAPI
Device #0: Speakers (3- Legato) Manufacturer: Model UID: Speakers (3- Legato) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f2973e42-c729-4dbf-b66a-6da499bb4ead}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (High Definition Audio Device) Manufacturer: Model UID: Speakers (High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{1893b8f0-043c-404b-bd90-8c3e3f3b60fc}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
