I’m still in the 30days trial modus and have problems with the sound output.
Like to solve this prob with a little help before buying the program…
I’m running windows 10, normally use foobar2000 to organize and play music from an external hard drive, Device Output from foobar is Realtek Digital Output (Optical) which means using a toslink cable to DENON AVC-A1D Amplifier
That’s the same output I try to use for Audirvana but get the message: It is not possible to change to integer modus
Cannot imagine this: Computer Output runs from Foobar2000 / Browser / System etc at (nearly) the same level to the Amp - Audirvana runs on same niveau through same toslink cable using same onboard soundcard - the reason is behind the ability to switch the sound button at Audirvana to “on/off”, but why do we have this ability?
That’s the max volume, to avoid cranking up to a too high level when volume control is enabled. For example to avoid damaging your hearing or your equipment.
If the volume control is disabled it should output at line level.
