Hi all,
I’m using the Dirac Live 2.0 plug in with Audirvana and it’s working very well if i keep Realtime Control enabled. I can modify the correction presets, toggle them on and off, and all the states save correctly.
However, if i disable “realtime control” so that the plugin GUI stops popping up, it seems to lock the plug in into a disabled state. The plugin loads, and if i go to configure with the song stopped, i can flip the switch to enable it, but it doesn’t stick.
Any ideas?
Thanks,
Dan
