MP60 2.1 is the preferred driver for Audirvana but MP60 2.1 is not showing in Audirvana. Audirvana Studio 2.2.3 (20203)
Windows 11 (22621) with 16GB physical RAM
Connected account of : Charles Feathers
Sync list: 0 folders
Library database path: C:\Users\csfea\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.50.127 on port 60055
TIDAL: Connected as PREMIUM
Active method: UPnP
Preferred device: [UPnP] MP-60-7c7438 Model UID:Lyngdorf MP-60 UID:uuid:b26d671c-86cf-424d-8e65-2af462f88eae
Selected device:MP-60-7c7438
Manufacturer: Lyngdorf
Model name: MP-60
Model UID: Lyngdorf MP-60
UID: uuid:b26d671c-86cf-424d-8e65-2af462f88eae
UPnP device at http://192.168.50.132:41169/b26d671c-86cf-424d-8e65-2af462f88eae.xml
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get::text/xml:dlna.org_pn=didl_s
http-get::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/3gpp:dlna.org_pn=heaacv2_l2_320
http-get::audio/mp4:dlna.org_pn=heaacv2_l2_320
http-get::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
rtsp-rtp-udp::text/xml:dlna.org_pn=didl_s
rtsp-rtp-udp::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/x-ms-wma:dlna.org_pn=wmafull
rtsp-rtp-udp::audio/x-ms-wma:dlna.org_pn=wmabase
rtsp-rtp-udp::audio/3gpp:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/mp4:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/mpeg:dlna.org_pn=mp3
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/flac:
http-get::audio/m4a:
http-get::application/ogg:
http-get::audio/wav:
http-get::audio/x-m4a:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::text/xml:
http-get::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-aiff:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: dB
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 MP-60-7c7438 Lyngdorf http://lyngdorf.com/ MP-60 http://lyngdorf.com/ 0050c27c7438 uuid:b26d671c-86cf-424d-8e65-2af462f88eae image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.50.132:8080/ DMR-1.50Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 MP-60-7c7438 Lyngdorf http://lyngdorf.com/ MP-60 http://lyngdorf.com/ 0050c27c7438 uuid:b26d671c-86cf-424d-8e65-2af462f88eae image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.50.132:8080/ DMR-1.50UPnP devices found : 1
Device #0: MP-60-7c7438
Location: http://192.168.50.132:41169/b26d671c-86cf-424d-8e65-2af462f88eae.xml
Model name: MP-60
Max. memory for audio buffers: 4730MB
Local Audio Engine: WASAPI
Device #0: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0298&SUBSYS_146212D2&REV_1001
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ed2818ba-a820-46fb-b2df-0560fbf712d1}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Chromecast devices found : 1
Device #0: Family Room Display
Model name: Google Nest Hub
