I had an audirvana app on an HP puter that died, have a new rig, need to switch the license to new rig. This is the second machine on said license, the first is running really well. Any help welcome, Thanx in advance.
Hello @Threadfin9349,
I have removed all your computers from the license database. You can now activate up to two PC running Windows 10.
To install Audirvana on your PC, you can proceed as follows:
- install trial version : https://audirvana.com/try-windows/
- unlock it by loading your license key
Thanx so much Damien3. New rig sounds fantastic. Audirvana is so sweet, and the support here is top notch.
I have installed a new hard drive in my computer to replace one that crashed can the license be removed from that drive seperately after I install the license or would I need to wait till I am notified that that it has been reset? I am on a Windows computer.
Hello @Raymond_Hutfles, i removed your computer in our database. You can now use your license in your new drive.
Demien, I have a similar problem. My older laptop died suddenly. How do I delete it so I can add a new computer? The only access I currently have is by the 2017 MacBook Pro. If you have to delete both that would be fine. I Thanks
Hello! I had to re-install Windows on my desktop (HP) and now I canât install Audirvana. Too many installations. Could you please remove the computer from your database? Thank you!
Hello @ArturBrait,
Also a similar issue with a dead laptop. I need to have my licenses reset if possible.
My thanks! Great response time from you all.
Hi Damien
I formatted my PC and reinstalled Audirvanna. It asks me to uninstall Audirvana before I can use my license again.
Are you able to please reset things on your end so I can the add the license again.
Thanks in advance
Hello @Drisie,
bonjour, jâai rĂ©installĂ© W10 sur mon PC et je nâarrive pas Ă rĂ©installer Audirvana en suivant la procĂ©dure âessai gratuitâ: pas de tĂ©lĂ©chargement et erreur 404 si je clique sur le lien.
Merci
Bonjour @jctfrance,
Pour installer et mettre Ă jour Audirvana sur Windows 10, vous avez besoin dâune application appelĂ©e App-Installer, cette application est installĂ©e par dĂ©faut lorsque vous utilisez Windows 10 1803. Si vous ne lâavez pas, vous pouvez lâinstaller gratuitement depuis le Microsoft Store ou avec ce lien : https://www.microsoft.com/en-us/p/app-installer/9nblggh4nns1?activetab=pivot:overviewtab
merci mais impossible dâinstaller cette application
Pour quelle raison vous ne pouvez pas installer cette application? Elle est installée par défaut dans Windows 10 si vous utilisez une version récente de Windows 10.
jâai rĂ©installĂ© windows 10 Ă partie dâun CD et formater mon ordi car W10 occupait toute la place de mon ordi et aprĂšs lâinstallation, jâai empĂ©chĂ© les mises Ă jour de W (PC LENOVO YOGA 330)
