Hi,
When will support for v3,5 end?
Many thanks
Shaun
Hi,
Many thanks
Shaun
Version 3.5 is already a legacy product. You’ll be able to get support for years to come. People are still using much older versions.
In general, you’ll be able to get support and ask questions as long is the product is still relevant.
Hi Bitracer, i have audirvana 3.5 lifetime suscriptions and i need the installer for windows 10. thanks
Go to the “Assistance” page and scroll down to the “Legacy versions” section:
can you reset the license? i get message from many licenses and i have deactivated one on macmini to install on windows, but it never works.
ok, thanks you and good day
