I have widows11 connected to a 65 inch lg 4k t.v. the symbol only shows half on certain albums. At other times the full symbol is shown,
Can you send a screenshot while it is fully displayed?
Hey do you know why HRA STREAMING isnt available in usa i wanted to try it with audervana because you can download from it thanks D
The difference looks to be 44.1kHz which makes the label longer when compared to 48kHz.
Don’t know about HRA.
Hey thanks well ive gotten a ps audio DSJ any advice on setting in audervana so i can play dsd ,right now on the ps its showing pcm
