The old MacMini worked without any problems until recently - with all applications…:-).
Audirvana Origin 2.5.7 (20507)
macOS Version 14.2 (Build 23C64) with 8GB physical RAM
Connected account of : Andre Natterer
AUTO: /Volumes/Music Toshiba/
Library database path: /Users/viper1/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49465
Max. memory for audio buffers: 3100MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
NAD NAD USB Audio 2.0
Model UID:NAD USB Audio 2.0:17AE:0005
UID:AppleUSBAudioEngine:NAD :NAD USB Audio 2.0:0000:1,2
Device: 10ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 40 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
Selected device:NAD USB Audio 2.0
Manufacturer: NAD
Model name: NAD USB Audio 2.0
Model UID: NAD USB Audio 2.0:17AE:0005
UID: AppleUSBAudioEngine:NAD :NAD USB Audio 2.0:0000:1,2
USB Vendor ID: 0x17ae
USB Product ID: 0x0005
ID 0x47
Max volume alert: Disabled
Multichannel: 10 channels
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
Channel 6 unused
Channel 7 unused
Channel 8 unused
Channel 9 unused
Number of channels: 10
Simple stereo device: No
Stream ID 0x48 10 channels starting at 1
12 virtual formats:
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
10 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
10 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
10 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
10 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
10 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
10 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
12 physical formats
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
Local devices found : 3
Device #0: ID 0x87 Ausgang (integriert)
Model UID: AppleHDA:88
Model name: Apple Inc. Ausgang (integriert)
Device #1: ID 0x78 HDMI
UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{CB3D-1140-00000000}
Model name: Apple Inc. HDMI
Device #2: ID 0x47 NAD USB Audio 2.0
Manufacturer: NAD
UPnP devices found : 1
Device #0: ID 0x0 : [LG] webOS TV UP75006LF
UID: uuid:8203bbc9-8f0d-707e-6a6d-b6836cf3af72
Manufacturer: LG Electronics.
Model name: LG TV
Chromecast devices found : 2
Device #0: 65PUS8102/12
Model name: TPM171E
Device #1: Onkyo TX-NR474 E5CF48
Model name: Onkyo TX-NR474
