I’m using the trial version and starting to get enthousiastic! But… I just notices that my iTunes playlist don’t have the order I carefully put the tracks in! There now ordered big artist of album. That’s a shame. How can I correct this? Can’t seem to get the order back I arranged them in in iTunes. Or see the order-number I gave it in iTunes. Help!
Hello @Rudidepudi, you can sort your playlist manually by enable the button “Sort also Manual Playlists” in the Sort Criteria in Audirvana Settings. You will then see your playlist as it is displayed in itunes
