Hello, Audirvana decides to organise my library at random. I would like to organize it by year. Can anybody help?
Sort Criteria - and the 12 current options therein, is the way forward with this from within your Album view as well as within Playlists.
Still hoping for a Shuffle by Album solution at some point to get past/extend beyond these limitations as, even when there is no selected criteria, there is still some default sorting going on which appears to reflect your folder(?) name structure and content.
Lots of sort options where the arrow (see below) is pointing (including year):
Just click the sort criteria as in the picture above and you can add/modifiy/remove sort options. Donāt forget to click āSave for Allā after you are done.
Also, try to explore the other options next to the sort criteria. You will find filter options etc.
Thank you, PasDeDeux, but take a look at my answer bellow, please. It seems that the display āArtistsā gives no option for organizing it by yearā¦
Thank you for your answer, Andy. At the selection āAlbumsā I understood and everything is OK, now. But when I press āArtistsā I cannot organize it by the year⦠Actually, Iām afraid thereās no such an optionā¦
Take a look at my Nina Simone discography. The order decreases and then grows again.
Hello,
There are some problems to organise albums by years with the current AS version (1.14.0) :
1- For a mix of streamed and local albums in MyMusic , āreleased dateā item in the menu sorts by year using the ārelease dateā of the album and not the āoriginal release dateā : for example, the Grateful Dead album Europeā72 has been remastered and re-released a few weeks ago, the released date is 07/2022 , If I sort using ārelease dateā , it appears in 2022 .I would also have the ability to sort with the āoriginal release dateā that is 1972 .
=> need the ability to sort MyMusic albums as today by ārelease dateā but also to sort them by āoriginal release dateā
2- for streamed albums (Qobuz in my case), there no ability to tune the sorting. In particular Favorites albums cannot be sorted by āreleased dateā. This is surprising because , it is possible in to do so in MyMusic for the same streamed album.
=> need the ability to sort Qobuz Favoirtes by ārelease dateā and by āoriginal release dateā
3- for Local album , there is the ability to sort by āyearā . It seems that it is a sort by ārelease dateā (why changing the name ?!) and there is no ability to sort by āoriginal release dateā . Surprisingly , when displaying the track of an album there is a column āoriginal release dateā but the displayed value is not the āoriginal release dateā but the date of the ārelease dateā
=> need the ability to sort local albums by ārelease dateā and by āoriginal release dateā
=>need to correct the display of the value in the column of the āoriginal release dateā in the track display of an album
=>need to have consistent naming between āyearā and ārelease dateā
I think these inconsistencies greatly affect the ease of use of the product.
Hello,
Hello @Antoine ,
You said 9 days ago concerning local albums on the user voice audirvana forum section:
I understand and I will see why we have done this before going any further.
What is the result of your analysis ? Will you correct ?
