Hi,
now that it seems the Synology version cant be made working I installed audirvana on my Linux mint computer with the NAS successfully mounted.
the service got started, avahi-daemon is running.
Here is the status.
compi2@compi2:/opt/audirvana/origin$ sudo ./setAsService.sh status
● audirvanaOrigin.service - Run audirvanaOrigin
Loaded: loaded (/etc/systemd/system/audirvanaOrigin.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2024-11-11 12:20:54 PST; 6s ago
Main PID: 16832 (audirvanaOrigin)
Tasks: 68 (limit: 18911)
Memory: 7.0M
CPU: 26ms
CGroup: /system.slice/audirvanaOrigin.service
└─16832 /opt/audirvana/origin/audirvanaOrigin
Nov 11 12:20:54 compi2 systemd[1]: Started Run audirvanaOrigin.
Nov 11 12:20:54 compi2 audirvanaOrigin[16832]: 2024-11-11 12:20:54.409 [info]: ============= Started Logging, Audirvana Origin 2.5.17 Linux x86_64 =============
Nov 11 12:20:54 compi2 audirvanaOrigin[16832]: 2024-11-11 12:20:54.410 [info]: Running on Linux 5.15.0-125-generic x86_64
Nov 11 12:20:54 compi2 audirvanaOrigin[16832]: 2024-11-11 12:20:54.410 [info]: No language set in settings, using system language: en_US.UTF-8
Nov 11 12:20:54 compi2 audirvanaOrigin[16832]: 2024-11-11 12:20:54.419 [warning]: EULA not accepted yet, showing it
Nov 11 12:20:54 compi2 audirvanaOrigin[16832]: 2024-11-11 12:20:54.421 [info]: RemoteServer: Server started and advertised on port 39897
Same network, No firewall blocking and avahi-daemaon running. Now when I start the app on the phone it first displays “connection in progress to NAS” until it times out, then shows the purple field with the computer. Tapping this I get the “unable to connect to the device” error .
Any ideas whats missing?
thank you, -m
