I am getting back into using Origin. When i used it in the past it would change sample rates on the device however now I am not see this change on the interface. I hear an audible click when there is a change which to me indicates something is changing. However the new sample rate is not displayed in the console. I notice in the debug info that the “active” sample rate is correct, but what i am viewing on the device still shows the original sample rate. I am not sure if this has to do with the locking.
Upsampling is disabled within the application
Here is the Debug info:
Audirvana Origin 2.5.12 (20512)
macOS Version 14.4 (Build 23E214) with 64GB physical RAM
Connected account of : Anthony Best
AUTO: /Users/anthonybest/Library/CloudStorage/[email protected]/Shared drives/Music Share
Library database path: /Users/anthonybest/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51410
Font size: regular
My Music
Library
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 62464MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Built-in Output
Model UID:
UID:
Active Sample Rate: 48kHz
Selected device:Universal Audio Thunderbolt
Manufacturer: Universal Audio, Inc.
Model name: Universal Audio, Inc. Universal Audio Thunderbolt
Model UID: com_uaudio_driver_UAD2System:Universal Audio Apollo
UID: com_uaudio_driver_UAD2AudioEngine:0
ID 0x6e
Audio buffer frame size : 15 to 3072 frames
Multichannel: 10 channels
Preferred stereo channels L:5 R:6
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
Channel 6 unused
Channel 7 unused
Channel 8 unused
Channel 9 unused
Number of channels: 10
Simple stereo device: No
Channel #0 :Stream 0 channel 4
Channel #1 :Stream 0 channel 5
Stream ID 0x6f 10 channels starting at 1
6 virtual formats:
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
10 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
6 physical formats
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 192kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 176.4kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 96kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 88.2kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 48kHz
10 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 44.1kHz
Local devices found : 3
Device #0: ID 0x68 LG UltraFine Display Audio
Manufacturer: LG Electronics Inc.
Model UID: LG UltraFine Display Audio:043E:9A4B
UID: AppleUSBAudioEngine:LG Electronics Inc.:USB Audio:3141000:2
USB Vendor ID: 0x043e
USB Product ID: 0x9a4b
Model name: LG Electronics Inc. LG UltraFine Display Audio
Device #1: ID 0x51 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #2: ID 0x6e Universal Audio Thunderbolt
