Since update 2.6 my VST plugins are now shrunk to approx 1/50th the size and stuck in the top right hand corner of the screen unable to move or resize.
Hi Antoine - using Izotope Ozone 11 Advanced Equalizer and Insight.
Hi @KTown,
Ozone 11? Are you sure it’s not Ozone 10 instead?
Can you send a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>My account
Hi Antoine - sorry my bad -correct I’m using Ozone 10 Pro VST3 plugins.
I figured out the scaling problem, I increased my screen resolution from 1080P to 4K and it seems Ozone 10 Plugins don’t scale well at 4K.
The plugin display fix you incorporated is working well with the plugins now displaying in the center of the screen - thank you!
Origin is operating correctly - the issue is with Izotope.
Thank you for the assistance.
Mike
