Is it possible to stream content from Audirvana only to Airplay device, but leave system sounds to system device?
Don’t think that’s possible since Airplay output is selected on system level.
i can route system sounds to Airplay and Audirvana stream to local speakers, but not the opposite
Maybe your endpoint also supports UPnP.
Hello
Can you explain me how use airplay with a PC to get SONOS Players?
