Downloaded and installed VST3 compatible program Ozone Imager 2 from iZotope. After install while streaming Qobuz I’m getting dropouts every 15-30 seconds. Is this program compatible with Audirvana? Thanks
Speakers (SMSL USB DAC)
WASAPI
Θ
Windows 10 (19044)
ASIO
PCM 44.1 48 88.2 96 176.4 192 768 768 DSD 64 128 256 Stereo
RAM 16GB
29.3%
CPU Load
35.4%
MQA Decoder
KERNEL STREAMING
lity
Volume Control ▷
DAC Input
Loading Decoding
Processing
Volume Levelling
► Upsampling ▸
ion
Jage
No volume control
Buffer 7.6GB Normal Polarity
Spl rate limit: No limit
No levelling
Fx Spatial iZotope, Inc. Ozone Imager 2 in RealTime
r8brain Custom
SW volume: -11.1dB
tion
Bufferized
Check audio HD profile
guage
PCM
PCM 401 40
FLAC
PCM
PCM
PCM
PCM
