the_bat
December 11, 2021, 3:42pm
1
Hi
I think I’ve asked this before but could you please implement some paragraph spacing in biographies and reviews. Currently we just get a single monolithic block of text which is very hard to read - especially where this a lot of text.
Many thanks
Alan
OffRode
December 12, 2021, 1:58am
3
Bravo ! Yes please include font size, colour, and translucent backgrounds are cool but problematic
Antoine
December 13, 2021, 9:44am
4
Hello @the_bat ,
Can you send some examples of a text like you describe? Are you using the MacOS or Windows 10 version? Is it with the normal or large font enabled?
the_bat
December 13, 2021, 2:26pm
5
This was using Studio on an M1 iMac with large fonts - small fonts is similar and even less readable.
Antoine
December 13, 2021, 2:29pm
6
Can you check on the Qobuz app how it’s displayed?
the_bat
December 13, 2021, 3:05pm
7
These are from from Qobuz
Other products (no names) insert a complete blank line between paragraphs, which I think is even better.
Antoine
December 13, 2021, 3:06pm
8
Here is what I get in French:
I will need to check this with Damien to understand what is going on depending on the region of the account
the_bat
December 13, 2021, 3:19pm
9
Thanks - that layout is what I’d hope to see.
glen
December 13, 2021, 3:45pm
10
@Antoine - This is happening in Windows (10 & 11) as well. Just an FYI.
Edit : Maybe it’s a code page difference for the different languages, and it’s not picking up the LF / CR characters?
Antoine
December 13, 2021, 4:43pm
11
The issue is from Qobuz that do not use the same way to send us the data between the language of the Qobuz account
We have been able to sort it out, it will be in the next update of Audirvāna Studio for MacOS and Windows.
Antoine
December 13, 2021, 5:02pm
14
On Windows or MacOS? Can you send a screenshot of an example?
OffRode
December 14, 2021, 10:50am
17
Hello @Antoine , Yes I would definitely call that improved !
Regards
Rob
