Hello,
When streaming a live album there is a short break between each track. Any way to avoid this ?
Olivier
Hello @Odhautco,
Hello,
See below:
Licence enregistrée pour odhautco
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sat May 30 16:57:44 2020
Library database path: /Users/odhautco/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Cuisine Model UID:Devialet Cuisine UID:uuid:8e323a0b-50ed-40d3-a92a-9d99a13b8236
UPnP device at http://192.168.1.44:34933/8e323a0b-50ed-40d3-a92a-9d99a13b8236.xml
ID 0x0 Cuisine Manufacturer:Devialet
Volume control: No
http-get::application/ogg:
http-get::audio/3gpp:
http-get::audio/3gpp2:
http-get::audio/aac:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/amr:
http-get::audio/amr-nb:
http-get::audio/amr-wb:
http-get::audio/atrac:
http-get::audio/atrac-advanced-lossless:
http-get::audio/flac:
http-get::audio/l16;channels=1;rate=44100:
http-get::audio/l16;channels=2;rate=44100:
http-get::audio/l16;rate=44100:
http-get::audio/l16;rate=44100;channels=1:
http-get::audio/l16;rate=44100;channels=2:
http-get::audio/l16;channels=1;rate=48000:
http-get::audio/l16;channels=2;rate=48000:
http-get::audio/l16;rate=48000:
http-get::audio/l16;rate=48000;channels=1:
http-get::audio/l16;rate=48000;channels=2:
http-get::audio/m4a:
http-get::audio/midi:
http-get::audio/mp4:
http-get::audio/mp4a:
http-get::audio/mp4a-latm:
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/mpeg4-generic:
http-get::audio/mpga:
http-get::audio/ogg:
http-get::audio/opus:
http-get::audio/vnd.wave:
http-get::audio/wav:
http-get::audio/wave:
http-get::audio/x-aac:
http-get::audio/x-ac3:
http-get::audio/x-aiff:
http-get::audio/x-flac:
http-get::audio/x-flac+ogg:
http-get::audio/x-m4a:
http-get::audio/x-m4b:
http-get::audio/x-m4p:
http-get::audio/x-mid:
http-get::audio/x-midi:
http-get::audio/x-mod:
http-get::audio/x-mpeg:
http-get::audio/x-mpeg3:
http-get::audio/x-mpequrl:
http-get::audio/x-ms-asf:
http-get::audio/x-ms-wma:
http-get::audio/x-vorbis:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-wav:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00.000
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Cuisine Devialet https://www.devialet.com The best sound in the world Phantom 2.11.5 https://www.devialet.com/phantom-speaker/ K50P00826P314 uuid:8e323a0b-50ed-40d3-a92a-9d99a13b8236 image/jpeg 32 32 24 /DvltRygelRendererPlugin-32x32x24.jpg image/jpeg 120 120 24 /DvltRygelRendererPlugin-120x120x24.jpg image/png 32 32 24 /DvltRygelRendererPlugin-32x32x24.png image/png 120 120 24 /DvltRygelRendererPlugin-120x120x24.png urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/DvltRygelRendererPlugin/RygelSinkConnectionManager /Event/DvltRygelRendererPlugin/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/DvltRygelRendererPlugin/RygelAVTransport /Event/DvltRygelRendererPlugin/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/DvltRygelRendererPlugin/RygelRenderingControl /Event/DvltRygelRendererPlugin/RygelRenderingControl DMR-1.51UPnP devices found : 2
Device #0: ID 0x0 Cuisine UID: uuid:8e323a0b-50ed-40d3-a92a-9d99a13b8236 Location: http://192.168.1.44:34933/8e323a0b-50ed-40d3-a92a-9d99a13b8236.xml
Device #1: ID 0x0 Salon UID: uuid:856edcf2-9672-4b1c-9fec-e96305e975e0 Location: http://192.168.1.27:37133/856edcf2-9672-4b1c-9fec-e96305e975e0.xml
Device #0: ID 0x2f Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:15 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Thanks,
Olivier
Bonjour,
2.11.5
Merci
Est-ce que ce problème est présent quelque soit l’album que vous écoutez?
Je l’ai remarqué quand j’écoute des albums live: il y a une coupure entre les morceaux.
Pouvez-vous me donner un exemple?
Alors, je l’ai remarqué récemment sur le nouvel album live de Roger Waters (Us+them). Je viens de le tester sur l’album Growing Up Live de Peter Gabriel.
Bonjour @Odhautco,
Nous venons de tester sur un Devialet Reactor avec un album live et la transition a été faite sans soucis. Est-ce que cela ce produit uniquement avec des albums live ou avec n’importe quel type d’album?
Bonjour,
Je vais le tester avec d’autres albums mais je ne vois pas de raison que ça soit différent. Pour information, j’utilise des devialet phantom premier connectés en wifi.
Bonne soirée,
Olivier
Je viens de le tester sur l’album Dark Side of the Moon et j’ai la même chose.
merci
Bonjour @Odhautco,
Votre problème est en lien avec l’implémentation du gapless (fonction passant d’une piste à une autre automatiquement) en UPnP de Devialet. Vous devez donc contacter Devialet à ce sujet pour qu’il priorise la résolution de ce problème.
Bonjour,
Je vous remercie pour votre réponse. J’ai contacté Devialet mais à vous lire visiblement il n’y a pas de solution immédiate… C’est assez frustrant.
Bien à vous,
Olivier
