Hello @Ironz,
I’m wondering if you are able to reproduce this issue while you are only using Audirvāna Studio without the Remote involved or not at all?
Hello @Ironz,
Hi @Antoine
I’ve just tested using the Studio app only, with no remote involved.
Unfortunately the problem persists:
Thank you for the gif, I will take a look at it with Damien as soon as possible.
Does your device using the latest firmware update available for it?
Hi @Antoine
The firmware version on my Cyrus streamer is one version old. However the latest version only added Qobuz playback via the manufacturers playback software, Cadence, afaik. Also updating the firmware is a pain as it can ONLY be carried out by a Cyrus retailer, I’m not able to do it myself
My other playback option, an Arcam AVR450, which also suffers with the pause button problem, DOES however have the latest firmware.
When you are pausing with your Arcam, can you press the debug info button and past it here?
Hi @Antoine
De-bug info as requested.
Please note that the Arcam doesn’t actually do ANYTHING after pausing, I have to choose the next track to continue playback of the album.
Audirvana Studio 1.10.2 (11002)
Windows 10 (19044) with 8GB physical RAM
Connected account of :
Per track: OFF
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: M:
Library database path: C:\Users\xxx\AppData\Local\Audirvana\Audirvana Studio\AudirvanaDatabase.sqlite
Listening on 2a00:23c6:6405:2001:d585:a2ba:9ed:479c on port 49857
HRA-Streaming: Connected as VirtualVault
Preferred device: ARCAM Arcam media client 002261cb1b90 Model UID:ARCAM Arcam media client 002261cb1b90 UID:uuid:3dcc7100-f76c-11dd-87af-002261cb1b90
Currently playing to UPnP device at 32 bits 44.1kHz
UPnP device at http://192.168.1.37:8080/dd.xml
Manufacturer: ARCAM
Model Name:
Model UID: ARCAM Arcam media client 002261cb1b90
UID: uuid:3dcc7100-f76c-11dd-87af-002261cb1b90
Volume control: No
Avoid RAW PCM streams: Yes
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/m4b:
http-get::audio/x-m4b:
http-get::audio/x-aac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/L16:
http-get::audio/L16;rate=11000;channels=1:
http-get::audio/L16;rate=11000;channels=2:
http-get::audio/L16;rate=11025;channels=1:
http-get::audio/L16;rate=11025;channels=2:
http-get::audio/L16;rate=22000;channels=1:
http-get::audio/L16;rate=22000;channels=2:
http-get::audio/L16;rate=22050;channels=1:
http-get::audio/L16;rate=22050;channels=2:
http-get::audio/L16;rate=44100;channels=4:
http-get::audio/L16;rate=44100;channels=6:
http-get::audio/L16;rate=44100;channels=8:
http-get::audio/L16;rate=8000;channels=1:
http-get::audio/L16;rate=8000;channels=2:
http-get::audio/L8:
http-get::audio/L8;rate=11000;channels=1:
http-get::audio/L8;rate=11000;channels=2:
http-get::audio/L8;rate=11025;channels=1:
http-get::audio/L8;rate=11025;channels=2:
http-get::audio/L8;rate=22000;channels=1:
http-get::audio/L8;rate=22000;channels=2:
http-get::audio/L8;rate=22050;channels=1:
http-get::audio/L8;rate=22050;channels=2:
http-get::audio/L8;rate=44100;channels=1:
http-get::audio/L8;rate=44100;channels=2:
http-get::audio/L8;rate=48000;channels=1:
http-get::audio/L8;rate=48000;channels=2:
http-get::audio/L8;rate=8000;channels=1:
http-get::audio/L8;rate=8000;channels=2:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
NrTracks: 1
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http://192.168.1.2:49152/audirvana/audio_146.wav
CurrentURIMetadata:
dc:titleMountain At My Gates</dc:title>
dc:creatorFoals</dc:creator>
upnp:artistFoals</upnp:artist>
upnp:genreAlternative Rock</upnp:genre>
upnp:albumArtURIhttp://192.168.1.2:49152/audirvana/artwork_1_146.jpg</upnp:albumArtURI>
upnp:albumWhat Went Down</upnp:album>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ALL RecordStorageMedium string NOT_IMPLEMENTED NOT_IMPLEMENTED LastChange string RelativeTimePosition string CurrentTrackURI string CurrentTrackDuration string CurrentRecordQualityMode string NOT_IMPLEMENTED NOT_IMPLEMENTED CurrentMediaDuration string AbsoluteCounterPosition i4 RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 0 AVTransportURI string CurrentTrackMetaData string AVTransportURIMetaData string TransportPlaySpeed string 1 1 NextAVTransportURI string PossibleRecordQualityModes string NOT_IMPLEMENTED NOT_IMPLEMENTED PossibleRecordStorageMedia string NOT_IMPLEMENTED NOT_IMPLEMENTED AbsoluteTimePosition string NextAVTransportURIMetaData string PlaybackStorageMedium string NETWORK NONE NETWORK CurrentTransportActions string PLAY STOP PAUSE SEEK NEXT PREVIOUS X_DLNA_SeekTime RecordMediumWriteStatus string NOT_IMPLEMENTED NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NOT_IMPLEMENTED NOT_IMPLEMENTED TransportState string NO_MEDIA_PRESENT STOPPED PLAYING TRANSITIONING PAUSED_PLAYBACK NO_MEDIA_PRESENT NumberOfTracks ui4 0 1 0 A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME CurrentTrack ui4 0 1 1 0 TransportStatus string OK OK ERROR_OCCURRED A_ARG_TYPE_SeekTarget stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Arcam media client 002261cb1b90 ARCAM http://www.arcam.co.uk ir-ser-FS2026-0500-0001_V2.5.14.36554-15 AVR450, AVR750 http://www.arcamradio.co.uk 0d0c1a0d0f2f1f2701019102ffff4bff uuid:3dcc7100-f76c-11dd-87af-002261cb1b90 image/png 48 48 32 /icon.png image/jpeg 48 48 32 /icon.jpg image/png 120 120 32 /icon2.png image/jpeg 120 120 32 /icon2.jpg urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport AVTransport/scpd.xml AVTransport/control AVTransport/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager ConnectionManager/scpd.xml ConnectionManager/control ConnectionManager/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl RenderingControl/scpd.xml RenderingControl/control RenderingControl/event DMR-1.50 VEN_2A2D&DEV_0001&SUBSYS_0001&REV_01 VEN_0033&DEV_0006&REV_01 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices Multimedia.DMR 0 1UPnP devices found : 2
Device #0Stream XP UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6AD1954 Location: http://192.168.1.39:8080/description.xml
Device #1Arcam media client 002261cb1b90 UID: uuid:3dcc7100-f76c-11dd-87af-002261cb1b90 Location: http://192.168.1.37:8080/dd.xml
Max. memory for audio buffers: 2032MB
Local Audio Engine: WASAPI
Local devices found : 0
