Bonjour ,
Si vous avez une solution
Pour la lecture des fichier DSD en native 64 ,128 . audirvana lit bien le fichier mais pas son au DAC en usb.
en réseau pas j’ai pas de souci .
driver pioneer ok , mac os ,
merci a vous
cdt
Audirvana Mac Version 3.5.34 (3564)
macOS 10.11.6 with 24576MB RAM
Licence enregistrée pour SOUSA JULIEN
No plugin active
AUTO: /Volumes/HDD 2TB/Musiques
Library database path: /Users/michclo/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 21504MB
Pioneer N-70A N-50A USB Audio
Model UID:Pioneer N-70A N-50A USB Audio:08E4:01A3
UID:AppleUSBAudioEngine:PIONEER HOME ELECTRONICS:Pioneer N-70A N-50A USB Audio:fd300000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x50 Pioneer N-70A N-50A USB Audio Manufacturer:PIONEER HOME ELECTRONICS
Model UID:Pioneer N-70A N-50A USB Audio:08E4:01A3 UID:AppleUSBAudioEngine:PIONEER HOME ELECTRONICS:Pioneer N-70A N-50A USB Audio:fd300000:1
Stream ID 0x51 2 channels starting at 1
32 virtual formats:
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Local devices found : 4
Device #0: ID 0x45 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:12 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3c Sortie de ligne intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:12 UID: AppleHDAEngineOutput:1B,0,1,3:1
Device #2: ID 0x38 Sortie numérique intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:12 UID: AppleHDAEngineOutput:1B,0,1,4:2
Device #3: ID 0x50 Pioneer N-70A N-50A USB Audio Manufacturer: PIONEER HOME ELECTRONICS Model UID: Pioneer N-70A N-50A USB Audio:08E4:01A3 UID: AppleUSBAudioEngine:PIONEER HOME ELECTRONICS:Pioneer N-70A N-50A USB Audio:fd300000:1
UPnP devices found : 1
Device #0: ID 0x0 N-50A UID: uuid:5F9EC1B3-ED59-79BE-4530-745e1c8f8f1f Location: http://192.168.1.33:8080/description.xml
Have you disabled software volume control?
oui le contrôle volume est désactive
cdt
Check the manual, this might be normal. It appears that DSD is supported only via UPnP. You can also try to contact Pioneer.
yes it works well in network, with photo album
in usb. no photo and no DSD
Thank you for your response, it’s cool.
cdt
Pioneer N50A fonctionne super bien en réseau DSD 64 et 128 , FLAC 192
en Usb . fonctionne sauf le DSD
Merci
Bonsoir ,
Trouver!!
installer le driver USB Pioneer , suivre la procedure a la lettre
ok DSD 64 et DSD 128
“DSD over PCM 1.0” dans la section périphérique de la page des paramètres audio.
ci joint le lien : pioneer site japonais uniquement
Merci a Vous
Cdt
