Play BluRay Audio on Audirvana
I’m currently testing audirvana studio and so far I’m thrilled. I have a question about that. I have some Bluray audio, partly as ISO, partly as MTS files. These are not displayed to me after the scan. Do I need to convert the Bluray to FLAC?
Hi @1070er,
Yes, you will need to. Here are the supported format by Audirvāna:
Thanks for the quick response
