I turned it off I just wanted to know if the DAC recognize the DSD and it does.
Yes, itās set over ppm 1.1
Debug info:
Audirvana Studio 2.2.3 (20203)
macOS 13.2.1 with 32GB physical RAM
Connected account of : Fabian Escalona
SW volume control: ON
AUTO: /Users/fabianescalona/Documents/Music
iTunes/Music library synchronization: last synchronized on Tue Feb 14 14:42:34 2023
Library database path: /Users/fabianescalona/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50115
Max. memory for audio buffers: 31744MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
GuangZhou FiiO Electronics Co.,Ltd FiiO K3
Model UID:FiiO K3:2972:0047
UID:AppleUSBAudioEngine:GuangZhou FiiO Electronics Co.,Ltd:FiiO K3:2112000:1
Active Sample Rate: 96kHz
Selected device:FiiO K3
Manufacturer: GuangZhou FiiO Electronics Co.,Ltd
Model name: GuangZhou FiiO Electronics Co.,Ltd FiiO K3
Model UID: FiiO K3:2972:0047
UID: AppleUSBAudioEngine:GuangZhou FiiO Electronics Co.,Ltd:FiiO K3:2112000:1
USB Vendor ID: 0x2972
USB Product ID: 0x0047
ID 0xbc
Stream ID 0xbd 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 8
Device #0: ID 0x3c BenQ LCD
Manufacturer: BNQ
Model UID: 09D11B80-0000-0000-111E-010380351E78
Model name: BNQ BenQ LCD
Device #1: ID 0x36 USB Audio CODEC
Manufacturer: Burr-Brown from TI
Model UID: USB Audio CODEC :08BB:2902
UID: AppleUSBAudioEngine:Burr-Brown from TI :USB Audio CODEC :2130000:1
USB Vendor ID: 0x08bb
USB Product ID: 0x2902
Model name: Burr-Brown from TI USB Audio CODEC
Device #2: ID 0xbc FiiO K3
Device #3: ID 0x51 BlackHole 16ch
Manufacturer: Existential Audio Inc.
Model UID: BlackHole16ch_ModelUID
UID: BlackHole16ch_UID
Model name: Existential Audio Inc. BlackHole 16ch
Device #4: ID 0x76 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #5: ID 0x59 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Device #6: ID 0x4e Multi-Output Device
Model UID: ~:AMS2_StackedOutput:0
Model name: Apple Inc. Multi-Output Device
Device #7: ID 0x4b blackhole + headphones
Model UID: ~:AMS2_StackedOutput:1
Model name: Apple Inc. blackhole + headphones
