I bought a ifi iSilencer plus to connect between ifi Micro iDSD BL.
Music sometimes lag (0.5s - 1s) when I play DSD file.
BUT I remove the iSilencer plus and re-connect ifi Micro iDSD BL,
AND it was working properly.
Maybe I found a root cause if I enabled 'Disable detection of iDevices on USB’.
Please following the debug info.
Audirvana Mac Version 3.5.40 (3570)
macOS 10.15.7 with 8192MB RAM
Registered to
AUTO: /Users/lvjianyi/Music/HiRes
iTunes/Music library synchronization: last synchronized on Wed Sep 16 23:33:24 2020
Library database path: /Users/lvjianyi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5000MB
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Active Sample Rate: 176.4kHz
ID 0x3e iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Audio buffer frame size : 53 to 4096 frames
Stream ID 0x3f 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 3
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:126 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3a HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:126 UID: AppleHDAEngineOutputDP:3,0,1,0:0:{6D1E-5AB8-01010101}
Device #2: ID 0x3e iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
