I was hoping this feature would be workaround for missing “Track Radio”, but seems it adds entire play list or album instead of just single selected track. In MacOS I can do “Clear queue” and it will reload queue based on the currently playing track, but not in Remote. Am I missing some trick here?
Hi @SimDim,
Are you using the iOS or Android Remote?
Hi @Antoine,
It is iOS remote.
I will check it out tomorrow and come back to you.
When you are talking about “Track Radio”, I assume you are talking about Tidal suggestion linked to a track? I tried this and it worked properly on the iOS Remote (the tracks added are in the fact the Track Radio). Can you send some screenshots?
