When I check play queue, the list is never in the some order as it shows in the album. Is this a setting what can be changed? Or is it a bug what has to be fixed? Please let me know, thank you very much.
The order is always correct when I add an album to the play queue. However if the “shuffle” option (play bar next to the track forward arrow) is turned on it will add in a random order.
off course, should thought about that. Forgot about the shuffle option. Thanks for the replay.
