Play with Audirvana/Hegel Question
Hi Antoine
What does Plays with Audirvana mean?
Does my amp support this?
Audirvana Origin 2.5.2 (20502)
macOS 12.6.9 with 8GB physical RAM
Connected account of : Mine
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sat May 27 12:00:06 2023
Library database path: /Users/gyug/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 61263
Active method: UPnP
Preferred device: [UPnP] Hegel Model UID:Hegel H120 UID:uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd
Selected device:Hegel
Manufacturer: Hegel
Model name: H120
Model UID: Hegel H120
UID: uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd
UPnP device at http://192.168.68.111:38400/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: Yes
http-get::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
http-get:
:audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
http-get:
:audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
http-get:
:audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get:
:audio/x-ms-wma:dlna.org_pn=wmapro
http-get::audio/mp4:dlna.org_pn=aac_iso
http-get:
:audio/3gpp:dlna.org_pn=aac_iso
http-get::audio/mp4:dlna.org_pn=aac_iso_320
http-get:
:audio/3gpp:dlna.org_pn=aac_iso_320
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get:
:audio/vnd.dlna.adts:dlna.org_pn=aac_adts_320
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Native Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:04:40.000
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Hegel Hegel http://www.hegel.com H120 H120 1.0 http://www.hegel.com uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd http://192.168.68.111 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.68.111:38400
UPnP devices found : 3
Device #0: ID 0x0 : [TV] Samsung 6 Series (55)
UID: uuid:6137e8fd-b94a-4462-803e-b01e39e59f5b
Manufacturer: Samsung Electronics
Model name: UN55KU630D
Device #1: ID 0x0 : HomePod
UID: uuid:c4f49284-1db6-134b-0080-0005cd88b467
Location: http://192.168.68.110:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Denon
Model name: Denon DHT-S516H
Device #2: ID 0x0 : Hegel
Manufacturer: Hegel
Model name: H120
Max. memory for audio buffers: 4214MB
Local Audio Engine: CoreAudio
Device #0: ID 0x32 Built-in Output
Model UID: AppleHDA:123
Hi @VSHegel, you should look at the page on our website :wink:
https://audirvana.com/partners/
Not yet, I contacted Hegel about this but I didn’t had a lot of feedback on this manner. I don’t know when Hegel device will be Plāys with Audirvāna but when ti will be done, it will be announced like we have done earlier this month.
Thank You.
Let me also reach out to Hegel Support and ask them.
" which have been certified to work with Audirvāna and whose customers can benefit from special advantages."
→ What advantages would a customer hear sonically? Can you pls expand
Sonically speaking, if the manufacturer would want to, we can give to the unit a special recommended settings like upsampling which could get you even better result when playing a song.
The other advantage for the user is getting a 3 month free trial of Audirvāna Studio for free :wink:
Thats a good to know.
BTW I got a response from hegel on the integration, and lets say its their honest take.
They think UPnP is good enough.
