|Just installed new version of studio
When i select a track to play from Qobuz it caches so slowly that the playback catches up with it and stops when it has nothing there to play. I haven’t changed anything in my system (Windows 10 into RME Dac) which has been working fine for at least a year.
I have uninstalled and reinstalled Studio. Turned everything on and off,
Broadband speed 83 mb/sec.
No change. Unusable on Qobuz but local files are fine.
Help please.
Here is the log:
2024-02-08 12:19:34.642 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-02-08 12:19:35.250 [error]: Not logged to Audirvana account: need to sign in
2024-02-08 12:19:36.113 [info]: RemoteServer: Server started and advertised on port 51359
2024-02-08 12:19:45.103 [info]: UPnP stack initialized using default interface
2024-02-08 12:19:45.322 [info]: UPnP web server started on 192.168.0.66:49152
2024-02-08 12:22:13.427 [error]: FLAC decoder: error reading HTTP stream
2024-02-08 12:22:49.264 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-02-08 12:22:50.790 [info]: UPnP stack initialized using default interface
2024-02-08 12:22:50.913 [info]: RemoteServer: Server started and advertised on port 51405
2024-02-08 12:22:50.994 [info]: UPnP web server started on 192.168.0.66:49152
2024-02-08 12:24:17.182 [error]: Unable to enable MMCSS on ASIO render thread: 1552
2024-02-08 12:24:17.890 [error]: FLAC decoder: error reading HTTP stream
2024-02-08 12:24:27.007 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-02-08 12:24:28.598 [info]: UPnP stack initialized using default interface
2024-02-08 12:24:28.722 [info]: RemoteServer: Server started and advertised on port 51442
2024-02-08 12:24:28.808 [info]: UPnP web server started on 192.168.0.66:49152
2024-02-08 12:24:55.496 [error]: Unable to enable MMCSS on ASIO render thread: 1552
2024-02-08 12:26:41.052 [error]: FLAC decoder: error reading HTTP stream
2024-02-08 12:28:14.875 [error]: Unable to enable MMCSS on ASIO render thread: 1552
2024-02-08 12:28:52.595 [error]: FLAC decoder: error reading HTTP stream
2024-02-08 12:30:42.595 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-02-08 12:30:44.384 [info]: UPnP stack initialized using default interface
2024-02-08 12:30:44.455 [info]: RemoteServer: Server started and advertised on port 49755
2024-02-08 12:30:44.607 [info]: UPnP web server started on 192.168.0.66:49152
2024-02-08 12:31:05.486 [error]: Unable to enable MMCSS on ASIO render thread: 1552
2024-02-08 12:32:42.181 [error]: FLAC decoder: error reading HTTP stream
2024-02-08 12:32:47.147 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-02-08 12:32:48.774 [info]: UPnP stack initialized using default interface
2024-02-08 12:32:48.888 [info]: RemoteServer: Server started and advertised on port 49915
2024-02-08 12:32:48.998 [info]: UPnP web server started on 192.168.0.66:49152
2024-02-08 12:33:14.379 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-02-08 12:33:15.800 [debug]: PlaybackController: setActivePlayQueuelocal
2024-02-08 12:33:15.912 [info]: UPnP stack initialized using default interface
2024-02-08 12:33:16.035 [info]: RemoteServer: Server started and advertised on port 49927
2024-02-08 12:33:16.120 [info]: UPnP web server started on 192.168.0.66:49152
2024-02-08 12:33:16.289 [debug]: ASIO: start selecting driver ASIO MADIface USB
2024-02-08 12:33:16.296 [debug]: ASIO: init for ASIO MADIface USB
2024-02-08 12:33:16.296 [debug]: ASIO: call init
2024-02-08 12:33:16.296 [debug]: ASIO: init done
2024-02-08 12:33:16.297 [debug]: ASIO: got out channels: 2
2024-02-08 12:33:16.297 [debug]: ASIO: init step 2
2024-02-08 12:33:16.297 [debug]: ASIO: init step 3
2024-02-08 12:33:16.297 [debug]: ASIO: init step 4
2024-02-08 12:33:16.298 [debug]: ASIO: init step 5
2024-02-08 12:33:16.299 [debug]: ASIO: init step 5b
2024-02-08 12:33:16.299 [debug]: ASIO: init step 5c: 2822400.000000
2024-02-08 12:33:16.299 [debug]: ASIO: init step 5c: 5644800.000000
2024-02-08 12:33:16.299 [debug]: ASIO: init step 5c: 11289600.000000
2024-02-08 12:33:16.299 [debug]: ASIO: init step 6
2024-02-08 12:33:16.299 [debug]: ASIO: init step 7
2024-02-08 12:33:16.299 [debug]: ASIO: init step 8
2024-02-08 12:33:16.300 [debug]: ASIO: init step 9
2024-02-08 12:33:16.300 [debug]: ASIO: init step 10
2024-02-08 12:33:27.977 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-02-08 12:33:29.422 [debug]: PlaybackController: setActivePlayQueuelocal
2024-02-08 12:33:29.532 [info]: UPnP stack initialized using default interface
2024-02-08 12:33:29.623 [info]: RemoteServer: Server started and advertised on port 49939
2024-02-08 12:33:29.746 [info]: UPnP web server started on 192.168.0.66:49152
2024-02-08 12:33:29.928 [debug]: ASIO: start selecting driver ASIO MADIface USB
2024-02-08 12:33:29.935 [debug]: ASIO: init for ASIO MADIface USB
2024-02-08 12:33:29.935 [debug]: ASIO: call init
2024-02-08 12:33:29.935 [debug]: ASIO: init done
2024-02-08 12:33:29.936 [debug]: ASIO: got out channels: 2
2024-02-08 12:33:29.937 [debug]: ASIO: init step 2
2024-02-08 12:33:29.937 [debug]: ASIO: init step 3
2024-02-08 12:33:29.937 [debug]: ASIO: init step 4
2024-02-08 12:33:29.937 [debug]: ASIO: init step 5
2024-02-08 12:33:29.938 [debug]: ASIO: init step 5b
2024-02-08 12:33:29.938 [debug]: ASIO: init step 5c: 2822400.000000
2024-02-08 12:33:29.938 [debug]: ASIO: init step 5c: 5644800.000000
2024-02-08 12:33:29.938 [debug]: ASIO: init step 5c: 11289600.000000
2024-02-08 12:33:29.938 [debug]: ASIO: init step 6
2024-02-08 12:33:29.938 [debug]: ASIO: init step 7
2024-02-08 12:33:29.938 [debug]: ASIO: init step 8
2024-02-08 12:33:29.939 [debug]: ASIO: init step 9
2024-02-08 12:33:29.940 [debug]: ASIO: init step 10
2024-02-08 12:33:39.258 [debug]: ASIO: start step 1
2024-02-08 12:33:39.258 [debug]: ASIO: start step 2
2024-02-08 12:33:39.319 [debug]: ASIO: start step 3
2024-02-08 12:33:39.319 [debug]: ASIO: start step 4 with 2 channels
2024-02-08 12:33:39.319 [debug]: ASIO: start step 5
2024-02-08 12:33:39.321 [debug]: ASIO: start step 6
2024-02-08 12:33:39.375 [error]: Unable to enable MMCSS on ASIO render thread: 1552
2024-02-08 12:42:59.998 [error]: FLAC decoder: error reading HTTP stream
2024-02-08 12:44:45.737 [error]: FLAC decoder: error reading HTTP stream
2024-02-08 12:44:45.737 [error]: Error reading FLAC file https://streaming-qobuz-std.akamaized.net/file?uid=2193658&eid=188590794&fmt=6&profile=raw&app_id=866251341&cid=1610792&etsp=1707399800&hmac=CmO7r91ywAZJBLnepRLr5chDzcc : FLAC__STREAM_DECODER_ABORTED
2024-02-08 12:44:45.741 [error]: Fatal error reading audio file https://streaming-qobuz-std.akamaized.net/file?uid=2193658&eid=188590794&fmt=6&profile=raw&app_id=866251341&cid=1610792&etsp=1707399800&hmac=CmO7r91ywAZJBLnepRLr5chDzcc aborting loading at frame 3307500
2024-02-08 12:45:20.124 [error]: FLAC decoder: error reading HTTP stream
2024-02-08 12:46:41.927 [info]: ============= Started Logging, Audirvana Studio 2.7.0 (20700) =============
2024-02-08 12:46:43.685 [info]: UPnP stack initialized using default interface
2024-02-08 12:46:43.703 [info]: RemoteServer: Server started and advertised on port 57061
2024-02-08 12:46:43.905 [info]: UPnP web server started on 192.168.0.66:49152
2024-02-08 12:47:57.695 [error]: Unable to enable MMCSS on ASIO render thread: 1552
