again a playback error, I don’t use a Mac so System Optimizer doesn’t help, below the debug information. This single error has had me reinstall Audirvana multiple times, I really consider switching to a conventional streamer and take the lesser sound for granted. This is not working, please solve:
Audirvana Studio 1.14.0 (11400)
Windows 11 (22000) with 4GB physical RAM
Connected account of : Andreas van Dongen
Sync list: 0 folders
Library database path: C:\Users\Andreas\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a02:a453:30b:1:c5d6:233d:aff:2c49 on port 49760
Max. memory for audio buffers: 2788MB
Speakers (Realtek(R) Audio)
Model UID:INTELAUDIO\FUNC_01&VEN_10EC&DEV_0257&SUBSYS_17AA5077&REV_1000
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b0ce3056-88f5-4cee-8288-cc50a7d0fab9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Manufacturer: Realtek
Model Name: Realtek(R) Audio
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0257&SUBSYS_17AA5077&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b0ce3056-88f5-4cee-8288-cc50a7d0fab9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
Multichannel: 8 channels
Channel bitmap: Oxff, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
2 output streams:
Number of active channels: 8, in 2 stream(s)
Channel #0 :Stream 1 channel 0
Channel #1 :Stream 1 channel 1
Channel #2 :Stream 1 channel 2
Channel #3 :Stream 1 channel 3
Channel #4 :Stream 1 channel 4
Channel #5 :Stream 1 channel 5
Channel #6 :Stream 1 channel 6
Channel #7 :Stream 1 channel 7
8 ch Integer PCM 16bit little endian 44.1kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 44.1kHz
8 ch Integer PCM 16bit little endian 48kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 48kHz
8 ch Integer PCM 16bit little endian 88.2kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 88.2kHz
8 ch Integer PCM 16bit little endian 96kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 96kHz
8 ch Integer PCM 16bit little endian 176.4kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 176.4kHz
8 ch Integer PCM 16bit little endian 192kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 192kHz
Device #0: Speakers (Combo384 Amanero) Manufacturer: Microsoft Model UID: USB\VID_16D0&PID_071A&REV_0196&MI_01 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e1b74492-43cd-4891-823a-c29a3b10c6d1}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Combo384 Amanero
Device #1: Speakers (Realtek(R) Audio) Manufacturer: Realtek Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0257&SUBSYS_17AA5077&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b0ce3056-88f5-4cee-8288-cc50a7d0fab9}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Realtek(R) Audio
