Audirvana has been working fine until I updated to macOS 10.14.6 Public Beta 3 (and subsequently with Beta 4) - since then when I try to replay tracks using Audirvana I get a 1 second or so burst of white noise when playback starts, but otherwise no sound at all. Playback animations continue - which suggest that some part of the app still thinks music is being played (e.g. the progress marker continues to move to the left etc.).
Changing the source and / or output device makes no difference to this.
Anyone got thoughts on what I can do about this?
PS - yes I know 10.14.6 is a beta preview - but Beta 4 is normally close to release, so maybe helpful to find out if this issue is macOS or Audirvana related.
Debug information appended.
Audirvana Mac Version 3.5.12 (3542)
macOS 10.14.6 with 32768MB RAM
Registered to Gavin Lawrie
AUTO: /Volumes/Media/SACDs
Library database path: /Users/glawrie/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
MM-1
Model UID:MM-1:19B5:0004
UID:AppleUSBAudioEngine:Bowers & Wilkins:MM-1:304:1
ID 0x5a MM-1 Manufacturer:Bowers & Wilkins
Model UID:MM-1:19B5:0004 UID:AppleUSBAudioEngine:Bowers & Wilkins:MM-1:304:1
3 available sample rates up to 48000Hz
32000
Stream ID 0x5b 2 channels starting at 1
6 virtual formats:
6 physical formats
Local devices found : 6
Device #0: ID 0x4f Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,3:0
Device #1: ID 0x46 Built-in Line Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,4:1
Device #2: ID 0x42 Built-in Digital Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,5:2
Device #3: ID 0x28 Display Audio Manufacturer: Apple Inc. Model UID: Display Audio:05AC:1105 UID: AppleUSBAudioEngine:Apple Inc.:Display Audio:25AA6502:2,1
Device #4: ID 0x5a MM-1 Manufacturer: Bowers & Wilkins Model UID: MM-1:19B5:0004 UID: AppleUSBAudioEngine:Bowers & Wilkins:MM-1:304:1
Device #5: ID 0x30 USB Audio Device Manufacturer: C-Media Electronics Inc. Model UID: USB Audio Device:0D8C:0014 UID: AppleUSBAudioEngine:C-Media Electronics Inc.:USB Audio Device:fd130000:2,1
