Since a couple of weeks ago, I’m experiencing issues when playing files from Tidal: it takes ages to start playing, then when it starts the sound is chopped every few seconds.
Moreover, the UI gets pretty unresponsive, frozen at times.
Tried to reinstall Audirvana: no difference.
Tried to increase/decrease biffer size: no difference.
No problems in playing any type of local files from the NAS.
I’m using Win10 and tried (1) direct PC > USB DAC (2), DLNA to Allo USBridge signature/Ropieee XL (via Ethernet) (3) and DLNA to Raspberry PiZero/Allo Miniboss/Volumio (via WiFi) with same results.
Therefore, I assume the issue not to be related with what’s coming after Audirvana.
Moreover, no problem in playing by Tidal app directly.
Again, until about two weeks ago everything was perfect.
Was anything changed at that time?
Any clue?
Thank you
Alessandro
