Same exact thing is happening with me using tidal. Started a couple months ago. Makes it unlistenable
Still skipping over here even after the latest update. It happens only when streaming Tidal (local files are fine), and skipping problem doesn’t happen in the Tidal app, just in audirvana. I’ve tried all manner of different settings as suggested in this thread and others on the topic. Very frustrating!!!
As others have noted, the latest 3.5 update did not solve this problem. I found a clue: looking at the release notes for the Tidal app, I noticed they issued an update to their app on March 29, 2021, to fix “issues playing the final 30 seconds of a track”. That’s exactly the problem Audirvana is having, so it may be worth contacting Tidal to see what changed on their end.
Tidal still annoyingly skipping randomly but at on almost all tracks … Is there any new info on potential solution?
Same here, I only use Tidal to stream and I don’t able to listen almost any playlist or album without skip or jump some tracks
Only 3 days left for my trial …
Damien, I like playing records, but I didn’t purchase Audirvāna to have it skip like an old records player.
Tidal skips and doesn’t play until the end of the track.
This is a Audirvāna problem because I have zero problem with my Atoll ST200 streamer software and tidal account. Tidal works perfectly with the Atoll and skips using Audirvāna.
Please fix this.
Brian
Audirvana Mac Version 3.5.46 (3576)
macOS 11.5.1 with 8192MB RAM
Registered to Brian Viger
SoX custom frequencies
Phase = 9
AUTO: /Volumes/Master Music SSD/
iTunes/Music library synchronization: last synchronized on Sat Mar 7 16:44:42 2020
Library database path: /Users/brianviger/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5970MB
USB HiRes Audio
Model UID:USB HiRes Audio:152A:86EF
UID:AppleUSBAudioEngine:DENAFRIPS:USB HiRes Audio:14300000:1
Active Sample Rate: 176.4kHz
Sample rate switching latency: 5s
Limit bitdepth to 24bit: ON
ID 0x50 USB HiRes Audio Manufacturer:DENAFRIPS
Model UID:USB HiRes Audio:152A:86EF UID:AppleUSBAudioEngine:DENAFRIPS:USB HiRes Audio:14300000:1
12 available sample rates up to 1536000Hz
1411200
1536000
Audio buffer frame size : 53 to 4096 frames
Stream ID 0x51 2 channels starting at 1
24 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
24 physical formats
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
Local devices found : 3
Device #0: ID 0x56 SHARP HDMI Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{104D-101E-00000000}
Device #1: ID 0x50 USB HiRes Audio Manufacturer: DENAFRIPS Model UID: USB HiRes Audio:152A:86EF UID: AppleUSBAudioEngine:DENAFRIPS:USB HiRes Audio:14300000:1
Device #2: ID 0x4a Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 ATOLL Streamer
I am using audirvana since the first generation and ad no problems with Tidal! But since a couple of months some tunes are skipping, but not all of them. I tried the same tunes direct from Tidal direct to my Chord dac and no skipping. Are you guy’s working on the problem? Thanks.
I am also experiencing skipping within tracks when using Tidal. There is no skipping within tracks when using Qobuz. I’m using Audirvana 3.5 on a Mac.
One more thing. I turned off Sox oversampling and the skipping has stopped. I prefer running Audirvana with oversampling, so this is not a good solution for me. I hope this helps find a fix for this issue. Thanks!
Nevermind. Still skipping on MQA tracks.
just loaded 3.5.50 still skipping tracks on tidal works perfectly on iphone and M1.
macOS 10.13.6 with 8192MB RAM
Licence enregistrée pour michel couture
Phase = 0
Max allowed volume: 99.3818
SW volume control: ON
AUTO: /Volumes/Public/Shared Music
iTunes/Music library synchronization: last synchronized on Wed Oct 27 20:09:31 2021
Library database path: /Users/neelix/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3100MB
USB DAC with XMOS xCORE U8 Output
Model UID:USB DAC with XMOS xCORE U8:20B1:000A
UID:AppleUSBAudioEngine:EMM Labs:USB DAC with XMOS xCORE U8:24400000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
Sample rate switching latency: 0.5s
ID 0x3b USB DAC with XMOS xCORE U8 Output Manufacturer:EMM Labs
Model UID:USB DAC with XMOS xCORE U8:20B1:000A UID:AppleUSBAudioEngine:EMM Labs:USB DAC with XMOS xCORE U8:26200000:1
Stream ID 0x3c 2 channels starting at 1
24 virtual formats:
32 physical formats
Device #0: ID 0x32 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x44 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutputDP:8,5,1,0:0:{8D06-0001-01010101}
Device #2: ID 0x3b USB DAC with XMOS xCORE U8 Output Manufacturer: EMM Labs Model UID: USB DAC with XMOS xCORE U8:20B1:000A UID: AppleUSBAudioEngine:EMM Labs:USB DAC with XMOS xCORE U8:26200000:1
UPnP devices found : 2
Device #0: ID 0x0 AFTT@ES(192.168.1.160) UID: uuid:9c99c3e8-d53a-1a87-0000-000038b27980 Location: http://192.168.1.160:41107/dev/9c99c3e8-d53a-1a87-0000-000038b27980/desc.xml
Device #1: ID 0x0 tvbureau[DMR] UID: uuid:b647a562-3d9c-ebc6-23e6-6bfa223fc50d Location: http://192.168.1.160:54393/upnp/dev/b647a562-3d9c-ebc6-23e6-6bfa223fc50d/desc
does someone doesn’t skip and anyone reading this from audirvana team?
we purchased the product to stream mqa from tidal. is there a way to go back to a version that don’t skip. i would like to enjoy the product like i use to.
i stated that it doesn’t skip on m1 i was wrong.
Phase = 0
Hog Mode is on
24 virtual formats:
32 physical formats
UPnP devices found : 3
Device #0: ID 0x0 Squeezebox Touch UID: uuid:C4763597-2C45-2F23-B3A4-7453199A47C7 Location: http://192.168.1.110:9000/plugins/UPnP/MediaRenderer.xml?player=00%3A04%3A20%3A22%3Ad4%3A03
Device #2: ID 0x0 AFTT@ES(192.168.1.160) UID: uuid:9c99c3e8-d53a-1a87-0000-000038b27980 Location: http://192.168.1.160:41107/dev/9c99c3e8-d53a-1a87-0000-000038b27980/desc.xml
Do you chase ambulances too?
You trolling.
