Playback speed and track time problems
Tracks are not playing at the correct speed (some too fast and others too slow) and the track times displayed while playing do not match up with the track duration on the library list. Has anyone else had this problem? If so how do you fix it? I can’t figure how to contact Audirvana for customer support.
To contact support send a mail to [email protected]
If you want help on this forum you need to provide more information. The best way to provide this is click on the ‘debug info’ in Audirvana. (see picture below). After that you can paste this info (Ctrl-V Windows, or Cmd-V Mac) in your next post here.
Audirvana Origin 2.2.2 (20202)
macOS Version 12.6 (Build 21G115) with 16GB physical RAM
Connected account of :
Replay Gain: by album
AUTO: /Users/jeremytokarek/Music/Count FLACula
Library database path: /Users/jeremytokarek/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49734
Max. memory for audio buffers: 15360MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Actual I/O buffer frame size: 2048
ROT RAP-1580
Model UID:49F48015-0000-0000-0119-010380000078
Device: 8ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 32 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
Selected device:RAP-1580
Manufacturer: ROT
Model name: ROT RAP-1580
Model UID: 49F48015-0000-0000-0119-010380000078
ID 0x2c
12 available sample rates up to 768000Hz
32000
Audio buffer frame size : 15 to 2304 frames
Current I/O buffer frame size : 2048
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 3
Channel 3 mapped to 2
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x2d 8 channels starting at 1
7 virtual formats:
3 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
5 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
7 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
21 physical formats
3 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
5 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
7 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
3 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
5 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
7 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
3 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
4 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
5 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
7 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
Device #0: ID 0x2c RAP-1580
Manufacturer: ROT
Device #1: ID 0x3b Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Your Mac has 16 GB RAM. Set the audio buffer in Audirvana to 4 GB (4000 MB) instead of what it is now.
This could be causing your problem. You can allways try to go higher in small increments, but start with 4GB.
You can also try (only for analysis purposes) to turn off r8brain upsampling.
Thanx for the advice Andy it totally worked out.
