Playback stops after a few seconds
music playback stops after 2 seconds. No idea why. Using windows 10 pro.
also, I assume remote does not work for studio yet.
@Antoine: yet another user with this problem!!!
Me too, but with flac files
This happen via DLNA
It’s interesting, I am getting the same issue (with a 2015 MB Pro 16mb) but only when trying to stream Qobuz. Local files (knock on wood) are playing fine).
yes, this happens to me when I attempt to stream through chromecast to my NAD C338.
Hello @corradomac, @Mikef, @corradomac, @PYSound and @dGrooveSF,
Does the issue occur only while you try to play tracks from Qobuz?
Hello @Antoine, the problems occurs when trying to play local files (m4a) via DLNA / UPnP. I don’t use Qobuz (at the moment at least).
Hi @Antoine. For me occurs with Tidal and some local music, but when I use via DLNA
happens with all files.
i was using cambridge cxnv2 as dac. changed dac and all is ok.
Yes, Only Qobuz. Tidal works fine. I am using a MacBook Pro running 11.3.1. I see the track loading, it plays for a few seconds then stops. Yesterday, it kept loading the track and started playback from the beginning then stops.
Qobuz for whatever reason appears to be the culprit (like others have said). Local files are playing fine - using a macbook 2015 11.31.1 to an outlaw 2160 mkii which uses the Linkplay Tech app/platform i see in misc streamers. Qobuz streams fine using the native Outlaw app.
Since the update 1.1, do you still have the same behavior?
i was listenign today and the song stopped every 5 seconds aprox , i restarted audirvana and same problem, i will try afternoon.
Yes @Antoine I still have the problem: nothing works, I can’t play any song or radio station. I just get a spinning beach ball sadly. I’ll send a crash report.
For me too continue the same problems @Antoine
With the update to 1.1, I am having the same problem with Tidal. So both Qobuz and Tidal are not functional!
The same issue as well with local files and it’s still present in 1.1
désolé Damien mais j 'ai un souffle qui couvre la musique quand je streame Qobuz et tidal vers une enceinte en UpNp alors que les fichiers locaux passent sans problÚme et ceci avec la 1.1
Audirvana Mac Version 1.1.0 (10010)
MAJ MEME CERTAINS FICHIERS LOCAUX NE PEUVENT ETRE LUS CAR J AI UN SOUFFLE QUI COUVRE LA MUSIQUE;;;;;;;HELP !!!
macOS 11.3.1 with 24576MB RAM
Connected account: [email protected] (jean marie boulley)
	Per track: OFF
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by track
AUTO: /Users/jeanmarieboulley/Music
Library database path: /Users/jeanmarieboulley/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52961
HRA-Streaming: Connected as VirtualVault
Preferred device: NAIM AUDIO LTD. SALON ORDI Model UID:Naim Audio Ltd. salon ordi UID:uuid:5F9EC1B3-ED59-79BB-4530-E8C74F06A8A5
UPnP device at http://192.168.1.16:8080/description.xml
ID 0x0 salon ordi
Manufacturer: Naim Audio Ltd.
Model Name:
Model UID: Naim Audio Ltd. salon ordi
UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F06A8A5
Volume control: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/wav:*
http-get::audio/x-mpegurl:
http-get:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/x_pm_flac:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
20 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz
0 physical formats
NrTracks: 1
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http://192.168.1.13:49154/audirvana/audio_9.pcm
CurrentURIMetadata: dc:titleDrama</dc:title>upnp:artistErika de Casier</upnp:artist>upnp:albumSensational</upnp:album>upnp:albumArtURIhttp://static.qobuz.com/images/covers/ga/9u/g6ffl1q2f9uga_600.jpg</upnp:albumArtURI>http://192.168.1.13:49154/audirvana/audio_9.pcm
nextURI: http://192.168.1.13:49154/audirvana/audio_11.pcm
nextURIMetadata: dc:titlePolite</dc:title>upnp:artistErika de Casier</upnp:artist>upnp:albumSensational</upnp:album>upnp:albumArtURIhttp://static.qobuz.com/images/covers/ga/9u/g6ffl1q2f9uga_600.jpg</upnp:albumArtURI>http://192.168.1.13:49154/audirvana/audio_11.pcm
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001
	</pnpx:X_compatibleId>
pnpx:X_deviceCategory
MediaDevices
	</pnpx:X_deviceCategory>
pnpx:X_hardwareId
BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01
	</pnpx:X_hardwareId>
df:X_deviceCategory
Multimedia.DMR
	</df:X_deviceCategory>
salon ordi
Naim Audio Ltd.
http://www.naimaudio.com
Naim Mu-so Qb all-in-one audio player
Mu-so Qb
20-004-0024
https://www.naimaudio.com/mu-so
E8C74F06A8A5
123810928305
image/jpeg
48
48
24
/BCO_device_lrg_icon.jpg
image/png
120
120
24
/BCO_device_sm_icon.png
image/png
48
48
24
/BCO_device_lrg_icon.png
text/html
120
120
24
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
http://192.168.1.16:80/1000/index.html
<X_Rhapsody-Extension>
urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:E8C74F06A8A5
</X_Rhapsody-Extension>
UPnP devices found : 4
Device #0: ID 0x0 salon ordi UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F06A8A5 Location: http://192.168.1.16:8080/description.xml
Device #1: ID 0x0 Salon UID: uuid:3caf5c07-1cd4-4810-864a-68e986211a8d Location: http://192.168.1.11:42894/3caf5c07-1cd4-4810-864a-68e986211a8d.xml
Device #2: ID 0x0 Décodeur TV UHD UID: uuid:00ababad-7947-1048-8a00-a89a93e49af1 Location: http://192.168.1.10:42300/description.xml
Device #3: ID 0x0 cuisine UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F089F01 Location: http://192.168.1.20:8080/description.xml
Max. memory for audio buffers: 12316MB
Local devices found : 4
Device #0: ID 0xcf Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:122 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Sortie intégrée
Device #1: ID 0xbe Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #2: ID 0x37 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1 Model Name: ma++ ingalls for Cycling '74 Soundflower (64ch)
Device #3: ID 0x2c AirParrot Manufacturer: squirrels Model UID: com_squirrels_driver_AudioDevice:AirParrotSpeakers UID: com_squirrels_driver_AudioEngine:0 Model Name: squirrels AirParrot
Problem is still there in version 1.2 :frowning:
@Antoine
