Hi there,
Still running the trial version of Audirvana (ending today) and I’ve just found out that playback does not start when upsampling to DSD (any bitrate). Right after clicking the Play icon, I can see the track is preloading into memory and halfway through the progress bar stops and the file simply does not start playing. This happens if I have the Raspberry PI 4 as a bridge between my PC and my Teac UD-503 DAC (although the settings of the RPI are identical to those of the DAC…). If I connect the DAC directly to the PC, upsampling to DSD works fine. Do you know what could be wrong?
Thanks in advance for your help!
