I can see urendu audio player as an output. As soon as I hit play, it is locked.
Audirvana Studio 1.8.5 (10805)
macOS 12.0.1 with 8GB physical RAM
Replay Gain: by album
SW volume control: ON
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sat Dec 4 20:08:39 2021
Library database path: /Users/charlesfeathers/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49435
Preferred device: JF LIGHT INDUSTRIES URENDU-015300-UPNP/AV Model UID:JF Light Industries urendu-015300-UPnP/AV UID:uuid:775c8887-d356-cace-8aff-d063b4015300
Currently playing to UPnP device at 32 bits 88.2kHz
UPnP device at http://172.24.1.209:49152/uuid-775c8887-d356-cace-8aff-d063b4015300/description.xml
ID 0x0 urendu-015300-UPnP/AV
Manufacturer: JF Light Industries
Model Name:
Model UID: JF Light Industries urendu-015300-UPnP/AV
UID: uuid:775c8887-d356-cace-8aff-d063b4015300
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::application/flac:
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
34 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 0:05:08
CurrentURI: http://172.24.1.156:49152/audirvana/audio_2.mqa.wav
CurrentURIMetadata:
dc:titleAlone With You</dc:title>
dc:creatorTevin Campbell</dc:creator>
upnp:artistTevin Campbell</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/811b6691/af60/4c0b/8d15/a4241a97abad/640x640.jpg</upnp:albumArtURI>
upnp:albumT.E.V.I.N.</upnp:album>
upnp:originalTrackNumber5</upnp:originalTrackNumber>
nextURI: http://172.24.1.156:49152/audirvana/audio_3.mqa.wav
nextURIMetadata:
dc:titleStrawberry Letter 23</dc:title>
upnp:originalTrackNumber6</upnp:originalTrackNumber>
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 urendu-015300-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.5.12 libupnpp 0.21.0 image/png 64 64 32 /uuid-775c8887-d356-cace-8aff-d063b4015300/icon.png /uuid-775c8887-d356-cace-8aff-d063b4015300/presentation.html uuid:775c8887-d356-cace-8aff-d063b4015300 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-775c8887-d356-cace-8aff-d063b4015300/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-775c8887-d356-cace-8aff-d063b4015300/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-775c8887-d356-cace-8aff-d063b4015300/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-775c8887-d356-cace-8aff-d063b4015300/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-775c8887-d356-cace-8aff-d063b4015300/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-775c8887-d356-cace-8aff-d063b4015300/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-775c8887-d356-cace-8aff-d063b4015300/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-775c8887-d356-cace-8aff-d063b4015300/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-775c8887-d356-cace-8aff-d063b4015300/evt-urn-schemas-upnp-org-service-ConnectionManager-1UPnP devices found : 1
Device #0: ID 0x0 urendu-015300-UPnP/AV UID: uuid:775c8887-d356-cace-8aff-d063b4015300 Location: http://172.24.1.209:49152/uuid-775c8887-d356-cace-8aff-d063b4015300/description.xml
Device #0: ID 0x2c Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
