Why does this happen with Melda Analyzer when playing 192kHz streams? You can reset the Analyzer and it will be okay for a minute or so and then it’s back to this. It only seems to happen when playing 192kHz streams. Not sure about higher sample rates as there aren’t really any available on Qobuz.
After resetting the Analyzer plugin it goes back to normal and looks like this:
It has always done this since I started using Melda.
