Hello, I am a longtime user of Audirvana, now suddenly it stops playing after the first track?
I guess I may have unchecked something? Or is it a known bug?
I have read the post on the same subject from last year but did not find an answer.
Many thanks for taking the time to look into it and for your help!!
Francesco
Audirvana Studio 2.2.2 (20202)
Windows 11 (22621) with 16GB physical RAM
Connected account of : Francesco Doenz
AUTO: C:\Users\franc\OneDrive\Desktop
Library database path: C:\Users\franc\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.248 on port 52438
TIDAL: Connected as FREE
Active method: UPnP
Preferred device: [UPnP] TDAI-3400-7C71FF Model UID:Lyngdorf TDAI-3400 UID:uuid:f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8
Selected device:TDAI-3400-7C71FF
Manufacturer: Lyngdorf
Model name: TDAI-3400
Model UID: Lyngdorf TDAI-3400
UID: uuid:f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8
UPnP device at http://192.168.1.116:33955/f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8.xml
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get::text/xml:dlna.org_pn=didl_s
http-get::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/3gpp:dlna.org_pn=heaacv2_l2_320
http-get::audio/mp4:dlna.org_pn=heaacv2_l2_320
http-get::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
rtsp-rtp-udp::text/xml:dlna.org_pn=didl_s
rtsp-rtp-udp::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/x-ms-wma:dlna.org_pn=wmafull
rtsp-rtp-udp::audio/x-ms-wma:dlna.org_pn=wmabase
rtsp-rtp-udp::audio/3gpp:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/mp4:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/mpeg:dlna.org_pn=mp3
http-get::audio/x-flac:
http-get::audio/flac:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/x-aac:
http-get::audio/ogg:
http-get::application/ogg:
http-get::audio/vorbis:
http-get::audio/m4a:
http-get::audio/wav:
http-get::audio/x-aiff:
http-get::audio/aiff:
http-get::audio/aac:
http-get::audio/wave:
http-get::text/xml:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-aac:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/wave:
DLNA 1.5: Yes
Native Gapless playback: Yes
Can play native DSD: No
Volume Control: dB
CurrentTransportState: TRANSITIONING
NrTracks: 1
MediaDuration: 0:02:55
CurrentURI: http://192.168.1.248:49152/audirvana/audio_24.wav
CurrentURIMetadata:
dc:titleConcerto No. 1 in E major, RV 269, “La primavera”: Largo</dc:title>
dc:creatorFranzjosef Maier</dc:creator>
upnp:artistFranzjosef Maier</upnp:artist>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/22/24/0054727742422_600.jpg</upnp:albumArtURI>
upnp:albumVivaldi: Le Quattro Stagioni, La Tempesta Di Mare, Il Piacere</upnp:album>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Stop,Seek
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 TDAI-3400-7C71FF Lyngdorf http://lyngdorf.com/ TDAI-3400 http://lyngdorf.com/ 0050C27C71FF uuid:f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.116/ DMR-1.51Current device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 TDAI-3400-7C71FF Lyngdorf http://lyngdorf.com/ TDAI-3400 http://lyngdorf.com/ 0050C27C71FF uuid:f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.116/ DMR-1.51UPnP devices found : 1
Device #0: TDAI-3400-7C71FF
Location: http://192.168.1.116:33955/f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8.xml
Max. memory for audio buffers: 4556MB
Local Audio Engine: WASAPI
Device #0: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0255&SUBSYS_10251582&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f59093c5-eaec-402e-9a7d-b1efe3156e71}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
