On my iMac. When I play a song from my hard drive, the information that Audirvana gives about the song in the lower left of the screen is FLAC 16/44.1kHz Stereo, in the lower right of the screen it says 24/192kHz Stereo.
I am assuming the song is playing in 16/44.1kHz while the maximum my UPnP amp can handle is 24/192kHz. Am I correct? Thanks.
Hello @dij,
macOS 11.1.0 with 8192MB RAM
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sat Jan 30 09:49:26 2021
Library database path: /Users/markdijulio/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Login failed
Preferred device: Marantz PM7000N Model UID:Marantz Marantz PM7000N UID:uuid:2d8925e7-3c8d-1d58-0080-0006783786de
UPnP device at http://192.168.0.23:60006/upnp/desc/aios_device/aios_device.xml
ID 0x0 Marantz PM7000N Manufacturer:Marantz
Volume control: No
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: file:///etc/sapphire/settings/nppl.xml
CurrentURIMetadata: dc:title""</dc:title>file:///etc/sapphire/settings/nppl.xmlupnp:class""</upnp:class>dc:creator""</dc:creator>upnp:genre""</upnp:genre>upnp:artist""</upnp:artist>upnp:album""</upnp:album>upnp:albumArtURI""</upnp:albumArtURI>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 GetCurrentState CurrentState out LastChange GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID X_SetShuffle InstanceID in A_ARG_TYPE_InstanceID Shuffle in X_Shuffle AVTransportURI string AVTransportURIMetaData string A_ARG_TYPE_CurrentState_AVTransport string A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_ObjectID string A_ARG_TYPE_SeekMode string TRACK_NR TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string AbsoluteCounterPosition ui4 AbsoluteTimePosition string CurrentMediaCategory string CurrentMediaDuration string CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL CurrentRecordQualityMode string CurrentTrack ui4 0 0 65535 1 CurrentTrackDuration string CurrentTrackMetaData string CurrentTrackURI string CurrentTransportActions string LastChange string NextAVTransportURI string NextAVTransportURIMetaData string NumberOfTracks ui4 0 0 65535 PlayMode ui4 0 PlaybackStorageMedium string PossiblePlaybackStorageMedia string PossibleRecordQualityModes string PossibleRecordStorageMedia string RecordMediumWriteStatus string RecordStorageMedium string RelativeCounterPosition i4 RelativeTimePosition string TransportPlaySpeed string 1 1 12 -12 TransportState string STOPPED STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING TransportStatus string OK OK ERROR_OCCURRED X_Shuffle boolean 0Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 BLL27200500671 uuid:2d8925e7-3c8d-1d58-0080-0006783786de urn:schemas-upnp-org:device:MediaRenderer:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 uuid:60eda500-3235-14a8-0080-0006783786de QPlay:1 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-denon-com:device:AiosServices:1 AiosServices Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 uuid:6a80bc6d-db87-11bd-0080-0006783786de urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-denon-com:device:ACT-Denon:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 BLL27200500671 uuid:38415c60-502a-1a2e-0d66-47f6aef0d67a AIOS:0001 1 165840 Wed 2020-11-04 13:48:32 1.583.161 00:06:78:37:86:DC en_NA 4 Aios 4.025 1 Production 00:06:78:37:86:DE urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/event urn:schemas-upnp-org:device:MediaServer:1 Marantz PM7000N Marantz http://www.marantz.com Shares User defined folders and files to other Universal Plug and Play media devices. Marantz PM7000N Aios 4.025 BLL27200500671 uuid:1c956aab-499e-1f22-0c52-fd3c5a677299 True True True True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManagerUPnP devices found : 5
Device #0: ID 0x0 Marantz PM7000N UID: uuid:2d8925e7-3c8d-1d58-0080-0006783786de Location: http://192.168.0.23:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Marantz PM7000N UID: uuid:60eda500-3235-14a8-0080-0006783786de Location: http://192.168.0.23:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 Marantz PM7000N UID: uuid:6a80bc6d-db87-11bd-0080-0006783786de Location: http://192.168.0.23:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Marantz PM7000N UID: uuid:38415c60-502a-1a2e-0d66-47f6aef0d67a Location: http://192.168.0.23:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Marantz PM7000N UID: uuid:1c956aab-499e-1f22-0c52-fd3c5a677299 Location: http://192.168.0.23:60006/upnp/desc/aios_device/aios_device.xml
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Since you have set upsampling to use maximum capabilites of your DAC:
You track is sent at 24/192 to your DAC, this is the info you have on the lower right of Audirvana
Thanks.
To make sure I understand. The file on my iMac is 16/44.1kHz (as I believe it was ripped from a CD into iTunes originally) but the file is upscaled in Audirvana to 24/192kHz and sent to play on my Marantz amp (via UPnP) at 24/192kHz, correct??
Yes, you are right about it. If you disable upsmapling you will see that the audio sent to your Marantz over UPnP will be 16/44
