When playing tracks from Qobuz, the music is constantly cutting out. Sometimes it restarts after a couple of seconds, other times I have to go to the computer to restart it. It makes it impossible to listen to the music.
I’m running Audirvana on an iMac with the latest operating system. I’ve updated to the latest version of Audirvana 3.3.3
Debug info
Audirvana Studio 3.3.3 (30303)
Running on iMac19,2
macOS 15.7.7 x86_64 with 16GB physical RAM
Connected account of :
Local network access: allowed
REMOTE CONTROL SERVER:
Listening on
en0 IPv4: 192.168.1.129
en0 IPv6: 2a0a:ef40:18a9:8c01:149d:78a5:6216:c565
en1 IPv4: 192.168.1.157
en1 IPv6: 2a0a:ef40:18a9:8c01:1866:ba47:ade1:74a9
on port 52536
LOADING/DECODING:
Max audio buffer size: 13312MB
Convolver: OFF
Internal EQ: OFF
Crossfeed: OFF
Balance: OFF
PLUGINS: NOT ACTIVE
Volume step size: 1dB
AUTO: /Volumes/My Passport for Mac/CD Uploads
Sync folders at startup: YES
Sort and display order: en
Library database path: /Users/richardcarpenter/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 582
Font size: regular
Favorites
Playlists
Streaming
Radios
Podcasts
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: no
Active method: UPnP
Ethernet
Wi-Fi
Preferred device: [UPnP] Model UID:Marantz Marantz NA6006 UID:uuid:f581dfb5-b53f-1295-0080-0005cdc97aea
Manufacturer: Marantz
Model name: Marantz NA6006
Model UID: Marantz Marantz NA6006
UID: uuid:f581dfb5-b53f-1295-0080-0005cdc97aea
Plays with Audirvāna: No
UPnP device at
8 available sample rates up to 5644800Hz
5644800
Volume control: Yes
Raw DSD (msb)
Channel 0: L
Channel 1: R
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
Universal gapless playback active: No
UPnP capabilities
DLNA 1.5: No
Service versions:
AVTransport: v1
RenderingControl: v1
ConnectionManager: v1
Native gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume control: scalar
Output configuration
Output streams: 1
Active channels: 2, in 1 stream(s)
Channel #0: Stream 0 channel 0
Channel #1: Stream 0 channel 1
16 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
0 physical formats
Current device state
Transport info:
Media info:
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://192.168.1.129:49152/audirvana/audioTest.pcm
CurrentURIMetadata: dc:titletestTitle</dc:title>http://192.168.1.129:49152/audirvana/audioTest.pcmPCM<DIDL-Lite xmlns:dc=" DCMI: DCMI Metadata Terms ; xmlns:upnp=“urn:schemas-upnp-org:metadata-1-0/upnp/” xmlns=“urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/” xmlns:dlna=“urn:schemas-dlna-org:metadata-1-0/”>
http://192.168.1.129:49152/audirvana/audioTest.pcm</res>
upnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creator"“</dc:creator>upnp:genre”“</upnp:genre>upnp:artist”“</upnp:artist>upnp:album”“</upnp:album>upnp:albumArtURI”"</upnp:albumArtURI>
nextURI: http://192.168.1.129:49152/audirvana/audio_f_1.wav
nextURIMetadata: dc:titleMagnificat & Nunc Dimittis: I. Magnificat</dc:title>http://192.168.1.129:49152/audirvana/audio_f_1.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorLondon Mozart Players</dc:creator>upnp:genreClassical</upnp:genre>upnp:artistLondon Mozart Players</upnp:artist>upnp:albumRoxanna Panufnik: Love Abide</upnp:album>upnp:albumArtURIhttps://static.qobuz.com/images/covers/vc/g0/ri0tsvrrfg0vc_600.jpg</upnp:albumArtURI>upnp:originalTrackNumber4</upnp:originalTrackNumber>
PlayMedium: NETWORK
Transport actions: Play,Stop,Restart,Previous,Pause
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/dsd:
http-get::audio/dsf:
http-get::audio/dff:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
Device description (live, downloaded from device)
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Family Room Marantz http://www.marantz.com Marantz NA6006 Aios 4.025 BBH36181101782 uuid:f581dfb5-b53f-1295-0080-0005cdc97aea ba153b urn:schemas-upnp-org:device:MediaRenderer:1 Family Room Marantz http://www.marantz.com Marantz NA6006 Aios 4.025 uuid:9bb7852f-fd34-1084-0080-0005cdc97aea 1000 QPlay:2 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/scpd/renderer_dvc/QPlay.xml /upnp/control/renderer_dvc/QPlay /upnp/event/renderer_dvc/QPlay urn:schemas-denon-com:device:AiosServices:1 AiosServices Marantz http://www.marantz.com Marantz NA6006 Aios 4.025 uuid:4725b06d-63e1-18ea-0080-0005cdc97aea urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-denon-com:device:ACT-Denon:1 Family Room Marantz http://www.marantz.com Marantz NA6006 Aios 4.025 BBH36181101782 uuid:eda7659e-e48e-eb1b-acfe-02e06069ec83 AIOS:0001 4 1763027084 Fri 2025-11-14 00:09:43 3.88.532 00:05:CD:C9:7A:E8 en_EU 4 Aios 4.025 1 Production 00:05:CD:C9:7A:EA urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/event urn:schemas-upnp-org:device:MediaServer:1 Family Room Marantz http://www.marantz.com Shares User defined folders and files to other Universal Plug and Play media devices. Marantz NA6006 Aios 4.025 BBH36181101782 uuid:383a2a84-12ac-6dcd-b8a4-207b76faabdc True True True True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManagerDevice description (cached from discovery)
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Family Room Marantz http://www.marantz.com Marantz NA6006 Aios 4.025 BBH36181101782 uuid:f581dfb5-b53f-1295-0080-0005cdc97aea ba153b urn:schemas-upnp-org:device:MediaRenderer:1 Family Room Marantz http://www.marantz.com Marantz NA6006 Aios 4.025 uuid:9bb7852f-fd34-1084-0080-0005cdc97aea 1000 QPlay:2 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/scpd/renderer_dvc/QPlay.xml /upnp/control/renderer_dvc/QPlay /upnp/event/renderer_dvc/QPlay urn:schemas-denon-com:device:AiosServices:1 AiosServices Marantz http://www.marantz.com Marantz NA6006 Aios 4.025 uuid:4725b06d-63e1-18ea-0080-0005cdc97aea urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-denon-com:device:ACT-Denon:1 Family Room Marantz http://www.marantz.com Marantz NA6006 Aios 4.025 BBH36181101782 uuid:eda7659e-e48e-eb1b-acfe-02e06069ec83 AIOS:0001 4 1763027084 Fri 2025-11-14 00:09:43 3.88.532 00:05:CD:C9:7A:E8 en_EU 4 Aios 4.025 1 Production 00:05:CD:C9:7A:EA urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/event urn:schemas-upnp-org:device:MediaServer:1 Family Room Marantz http://www.marantz.com Shares User defined folders and files to other Universal Plug and Play media devices. Marantz NA6006 Aios 4.025 BBH36181101782 uuid:383a2a84-12ac-6dcd-b8a4-207b76faabdc True True True True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManagerUPnP devices found : 1
Device #0: ID 0x0 : Family Room
CoreAudio
Device #0: ID 0x4c Built-in Output
Model UID: AppleHDA:15
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
