Hello
Thanks for your email. Here’s the Debug Info from the other evening. [Note: I sent this to you on Monday by responding to your email that you sent me, only to discover that it couldn’t be delivered to the email box from which you had emailed me!]
Michael
macOS 10.11.6 with 8192MB RAM
Registered to Michael Stewart
Sync list: 2 folders
AUTO: /Users/michaelstewart/Music/Lossless rips
AUTO: /Users/michaelstewart/Music/Qobuz
Library database path: /Users/michaelstewart/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
USB HiRes Audio
Model UID:USB HiRes Audio:152A:86EF
UID:AppleUSBAudioEngine:DENAFRIPS:USB HiRes Audio:26400000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x26 USB HiRes Audio Manufacturer:DENAFRIPS
Model UID:USB HiRes Audio:152A:86EF UID:AppleUSBAudioEngine:DENAFRIPS:USB HiRes Audio:26400000:1
Stream ID 0x27 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 3
Device #0: ID 0x3b Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x44 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutputDP:8,5,1,0:0:{6252-3700-00000000}
Device #2: ID 0x26 USB HiRes Audio Manufacturer: DENAFRIPS Model UID: USB HiRes Audio:152A:86EF UID: AppleUSBAudioEngine:DENAFRIPS:USB HiRes Audio:26400000:1
