I don’t know how to add or delete tracks . Normal Audirvana was so easy but in Origin it’s completely different. Please could somebody help. I’m using Mac 10.13.6 .
Hello @Gabrielle_Sherwin,
If you want to remove a track from a playlist, you need to right-click on it. If you do not have the option to remove it, then it means that you created a smartplaylist and you need to change it’s rules or filters.
I use a Mac so don’t have right click. It used to work in Audirvana before it’s just in Origin it doesn’t work. I didn’t think I’d created a smart playlist but that would explain a lot. I can’t add tracks either.
