Hi
When adding tracks to a playlist, at times i don’t see that last one , two or thrree added when checking what i i have there and so i add them again, sometimes a double up not always.
At other times when loading the program all is good you can see the entire list.
I am using Windows 10 as the OS for the trial.
cheers
Dennis
Maybe just a refresh bug…
When you add them and see one missing…
just click elsewhere or another playlist or your albums…
then come back to that playlist and see if it was there before adding it again…
Now i realise that it’s becuase i cannot see all the songs in the playlist for some unknown reason. They are there but no matter what i do cannot scroll to the end.
Anyone have that issue?
cheers
