Hi,
When I want to listen to one of my Qobuz playlists, selecting the tracks manually takes me to the album instead of the track itself.
Am I missing something?
Hi,
Hi @Nemrod,
Can you send a screenshot highlighting where you click in Audirvāna Studio?
Hi,
Sure, I’ll do it back home on Monday
Best
Thanks for posting the specific albums/artist that you did. I had heard “No Roots” long ago on peasant FM radio and never remembered the artist’s name. Love that song and now I know who does it and there’s more albums to listen to.
I’ll also investigate your issue and look for a solution or confirm same problem.
Cheers!
You’re welcome.
It is possible, but you need to push play, then click & click…
Can you try to tap on this icon when you open the playlist?
Can you rephrase that?
When you are on the playlist on your Remote, can you please tap on the eye icon you see next to the three dot icon?
