Hi Damien3,
I could not send you the debug data as you suggested (“new member not more than 10 posts”). Not easy… so finally I created a new member. I hope you get this:
macOS 11.1.0 with 8192MB RAM
Die Testversion verwendet eine Demo-Lizenz
Sync list: 0 folders
Library database path: /Users/richardschmitz/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Linn Musikzimmer:UPnP AV Model UID:Linn Products Ltd Linn Musikzimmer:UPnP AV UID:uuid:4c494e4e-0026-0f22-0c53-014521610171
UPnP device at http://192.168.178.20:55178/4c494e4e-0026-0f22-0c53-014521610171/Upnp/device.xml
ID 0x0 Linn Musikzimmer:UPnP AV Manufacturer:Linn Products Ltd
Volume control: No
http-get::audio/mp4:
http-get::application/vnd.apple.mpegurl:
http-get::audio/aac:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/aifc:
http-get::audio/x-aifc:
http-get::audio/x-m4a:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/x-ogg:
http-get::application/ogg:
http-get::audio/wav:
http-get::audio/wave:
http-get::audio/x-wav:
http-get::audio/x-ms-wma:
http-get::audio/x-ms-asf:
http-get::audio/x-ms-wax:
http-get::audio/x-ms-wvx:
http-get::video/x-ms-asf:
http-get::video/x-ms-wax:
http-get::video/x-ms-wvx:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/mp1:
http-get::audio/x-mpegurl:
http-get::audio/mpegurl:
http-get::audio/x-scpls:
http-get::text/xml:
tidalhifi.com:::*
qobuz.com:::*
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
24 virtual formats:
0 physical formats
CurrentTransportState: TRANSITIONING
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_SetAVTransportURI_InstanceID CurrentURI in A_ARG_TYPE_SetAVTransportURI_CurrentURI CurrentURIMetaData in A_ARG_TYPE_SetAVTransportURI_CurrentURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_GetMediaInfo_InstanceID NrTracks out A_ARG_TYPE_GetMediaInfo_NrTracks MediaDuration out A_ARG_TYPE_GetMediaInfo_MediaDuration CurrentURI out A_ARG_TYPE_GetMediaInfo_CurrentURI CurrentURIMetaData out A_ARG_TYPE_GetMediaInfo_CurrentURIMetaData NextURI out A_ARG_TYPE_GetMediaInfo_NextURI NextURIMetaData out A_ARG_TYPE_GetMediaInfo_NextURIMetaData PlayMedium out A_ARG_TYPE_GetMediaInfo_PlayMedium RecordMedium out A_ARG_TYPE_GetMediaInfo_RecordMedium WriteStatus out A_ARG_TYPE_GetMediaInfo_WriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_GetTransportInfo_InstanceID CurrentTransportState out A_ARG_TYPE_GetTransportInfo_CurrentTransportState CurrentTransportStatus out A_ARG_TYPE_GetTransportInfo_CurrentTransportStatus CurrentSpeed out A_ARG_TYPE_GetTransportInfo_CurrentSpeed GetPositionInfo InstanceID in A_ARG_TYPE_GetPositionInfo_InstanceID Track out A_ARG_TYPE_GetPositionInfo_Track TrackDuration out A_ARG_TYPE_GetPositionInfo_TrackDuration TrackMetaData out A_ARG_TYPE_GetPositionInfo_TrackMetaData TrackURI out A_ARG_TYPE_GetPositionInfo_TrackURI RelTime out A_ARG_TYPE_GetPositionInfo_RelTime AbsTime out A_ARG_TYPE_GetPositionInfo_AbsTime RelCount out A_ARG_TYPE_GetPositionInfo_RelCount AbsCount out A_ARG_TYPE_GetPositionInfo_AbsCount GetDeviceCapabilities InstanceID in A_ARG_TYPE_GetDeviceCapabilities_InstanceID PlayMedia out A_ARG_TYPE_GetDeviceCapabilities_PlayMedia RecMedia out A_ARG_TYPE_GetDeviceCapabilities_RecMedia RecQualityModes out A_ARG_TYPE_GetDeviceCapabilities_RecQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_GetTransportSettings_InstanceID PlayMode out A_ARG_TYPE_GetTransportSettings_PlayMode RecQualityMode out A_ARG_TYPE_GetTransportSettings_RecQualityMode Stop InstanceID in A_ARG_TYPE_Stop_InstanceID Play InstanceID in A_ARG_TYPE_Play_InstanceID Speed in A_ARG_TYPE_Play_Speed Pause InstanceID in A_ARG_TYPE_Pause_InstanceID Seek InstanceID in A_ARG_TYPE_Seek_InstanceID Unit in A_ARG_TYPE_Seek_Unit Target in A_ARG_TYPE_Seek_Target Next InstanceID in A_ARG_TYPE_Next_InstanceID Previous InstanceID in A_ARG_TYPE_Previous_InstanceID LastChange string A_ARG_TYPE_SetAVTransportURI_InstanceID ui4 A_ARG_TYPE_SetAVTransportURI_CurrentURI string A_ARG_TYPE_SetAVTransportURI_CurrentURIMetaData string A_ARG_TYPE_GetMediaInfo_InstanceID ui4 A_ARG_TYPE_GetMediaInfo_NrTracks ui4 A_ARG_TYPE_GetMediaInfo_MediaDuration string A_ARG_TYPE_GetMediaInfo_CurrentURI string A_ARG_TYPE_GetMediaInfo_CurrentURIMetaData string A_ARG_TYPE_GetMediaInfo_NextURI string A_ARG_TYPE_GetMediaInfo_NextURIMetaData string A_ARG_TYPE_GetMediaInfo_PlayMedium string A_ARG_TYPE_GetMediaInfo_RecordMedium string A_ARG_TYPE_GetMediaInfo_WriteStatus string NOT_IMPLEMENTED NOT_WRITABLE PROTECTED UNKNOWN WRITABLE A_ARG_TYPE_GetTransportInfo_InstanceID ui4 A_ARG_TYPE_GetTransportInfo_CurrentTransportState string NO_MEDIA_PRESENT PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING STOPPED TRANSITIONING A_ARG_TYPE_GetTransportInfo_CurrentTransportStatus string ERROR_OCCURRED OK A_ARG_TYPE_GetTransportInfo_CurrentSpeed string A_ARG_TYPE_GetPositionInfo_InstanceID ui4 A_ARG_TYPE_GetPositionInfo_Track ui4 0 2147483647 1 A_ARG_TYPE_GetPositionInfo_TrackDuration string A_ARG_TYPE_GetPositionInfo_TrackMetaData string A_ARG_TYPE_GetPositionInfo_TrackURI string A_ARG_TYPE_GetPositionInfo_RelTime string A_ARG_TYPE_GetPositionInfo_AbsTime string A_ARG_TYPE_GetPositionInfo_RelCount i4 A_ARG_TYPE_GetPositionInfo_AbsCount i4 A_ARG_TYPE_GetDeviceCapabilities_InstanceID ui4 A_ARG_TYPE_GetDeviceCapabilities_PlayMedia string A_ARG_TYPE_GetDeviceCapabilities_RecMedia string A_ARG_TYPE_GetDeviceCapabilities_RecQualityModes string A_ARG_TYPE_GetTransportSettings_InstanceID ui4 A_ARG_TYPE_GetTransportSettings_PlayMode string NORMAL A_ARG_TYPE_GetTransportSettings_RecQualityMode string A_ARG_TYPE_Stop_InstanceID ui4 A_ARG_TYPE_Play_InstanceID ui4 A_ARG_TYPE_Play_Speed string A_ARG_TYPE_Pause_InstanceID ui4 A_ARG_TYPE_Seek_InstanceID ui4 A_ARG_TYPE_Seek_Unit string ABS_COUNT ABS_TIME CHANNEL_FREQ FRAME REL_COUNT REL_TIME TAPE-INDEX TRACK_NR A_ARG_TYPE_Seek_Target string A_ARG_TYPE_Next_InstanceID ui4 A_ARG_TYPE_Previous_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Linn Musikzimmer:UPnP AV Linn Products Ltd Klimax Renew DSM uuid:4c494e4e-0026-0f22-0c53-014521610171 image/png 120 50 32 http://192.168.178.20:55178/4c494e4e-0026-0f22-0c53-01452161013f/Upnp/resource/res/icons/Fw867Renew.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /4c494e4e-0026-0f22-0c53-014521610171/Upnp/upnp.org-AVTransport-1/service.xml /4c494e4e-0026-0f22-0c53-014521610171/upnp.org-AVTransport-1/control /4c494e4e-0026-0f22-0c53-014521610171/upnp.org-AVTransport-1/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /4c494e4e-0026-0f22-0c53-014521610171/Upnp/upnp.org-ConnectionManager-1/service.xml /4c494e4e-0026-0f22-0c53-014521610171/upnp.org-ConnectionManager-1/control /4c494e4e-0026-0f22-0c53-014521610171/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /4c494e4e-0026-0f22-0c53-014521610171/Upnp/upnp.org-RenderingControl-1/service.xml /4c494e4e-0026-0f22-0c53-014521610171/upnp.org-RenderingControl-1/control /4c494e4e-0026-0f22-0c53-014521610171/upnp.org-RenderingControl-1/eventUPnP devices found : 1
Device #0: ID 0x0 Linn Musikzimmer:UPnP AV UID: uuid:4c494e4e-0026-0f22-0c53-014521610171 Location: http://192.168.178.20:55178/4c494e4e-0026-0f22-0c53-014521610171/Upnp/device.xml
Max. memory for audio buffers: 6172MB
Device #0: ID 0x52 MacBook Pro Lautsprecher Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #1: ID 0x30 Linn Songcast Manufacturer: Linn Products Ltd Model UID: uk_co_linn_songcast:Linn Songcast UID: uk_co_linn_songcast_audioengine:0
