@ Damien - thanks for your reply. Please see log report
Audirvana 3.5.3
Manual: (OFFLINE) D:\Music
Library database path: C:\Users\Ghulam\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
Max. memory for audio buffers: 6536MB
Local Audio Engine:ASIO 2 driver version 794
OPPO USB AUDIO 2.0 ASIO Driver
Model UID:OPPO USB AUDIO 2.0 ASIO Driver
Device: 2ch 32bits Integer, 8 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
OPPO USB AUDIO 2.0 ASIO Driver Manufacturer:
Model UID:OPPO USB AUDIO 2.0 ASIO Driver UID:OPPO USB AUDIO 2.0 ASIO Driver
Device #0: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2
Device #1: OPPO USB AUDIO 2.0 ASIO Driver Manufacturer: Model UID: OPPO USB AUDIO 2.0 ASIO Driver UID: OPPO USB AUDIO 2.0 ASIO Driver
