Reinstalled Windows, and had no idea that I had to uninstall Audirvana before doing that.
Please reset my licenses from my DB
ma clé de licence ne fonctionne pas.il est difficile de savoir si c"est un o ou un zero.
Ne tape pas, copie et colle
Bonjour,
Il n’y a jamais de O dans les clés de licence. Il s’agit obligatoirement du nombre 0.
Effectivement, comme l’indique très justement @RunHomeSlow, il est préférable de copier-coller directement la clé de licence.
Bien musicalement,
Damien
je ne saurais pas la copié j’ai du rénitialiser mes ordis.
Hello @calaf,
I have removed all your computers from the license database.
You can now activate up to two computers.
To install Audirvana on your computer, you can proceed as follows:
- install trial version : https://audirvana.com/try/
- unlock it by loading your license key
Hello Damien3.
I have the same problem as @calaf. I have reinstalled windows10 and now I can’t install audirvana because a problem with the installations numbers. Please, would you remove all my computers from the license database?
Thank you
install windows 11 and I would need you to restore my licenses, thank you!
Hello Damien3.
I have the same problem. I have reinstalled windows and now I can’t install audirvana because a problem with the installations numbers. Please, would you remove all my computers from the license database? Audirvana 3.5.
Thank you
Damien, please help me remove all my computers from the license database too. having the same problem.
